Ethernet question
Old Sep 5, 2005 | 12:44 AM
ErnScott's Avatar
Ford lariet...I won't add to the router/hub part of your adventure...but if you are running OSX 10.3 on up...you do not the installation disc they give you. All you need is all built into your operating system already. As a matter of fact, often times when you add the garbage they send you, it has an overall negative affect on your system.
Old Sep 5, 2005 | 12:45 AM
Ford Lariat's Avatar
Originally Posted by Tical84
Right.
If they are in seperate rooms i suggest not using Ethernet, get a wireless adapter for it.
A wireless router will send the signal to the wireless adapter which will plug into each computer you want wireless.
Okay. Are the wireless router and a wireless adapter bought separately?
How are the wireless adapters plugged into the computers?
Old Sep 5, 2005 | 12:46 AM
Yeah, that installation cd didn't do anything for me. I DO have Built-In Ethernet, though, if that means anything?
Old Sep 5, 2005 | 12:48 AM
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
But you said that you were going to use wireless for the lap top? So you wont have to use the ethernet on it.
Old Sep 5, 2005 | 12:51 AM
I am really confused. I don't know. I might just buy the Airport base station and get it over with. I feel so lost...
Old Sep 5, 2005 | 12:52 AM
PSS-Mag's Avatar
Yes they are sperate... and the adapter plug different ways.. you can get PCI, USB, PCMIA, etc, etc,
They are the same as an ethernet card or adapter only no place to plug wires and have an antenna instead.
Old Sep 5, 2005 | 12:54 AM
ErnScott's Avatar
OK. If you have a Powerbook, it has built-in wireless as well, If you have an iBook, it might (and usually do).
So assuming you have wireless built in...the chain works like this:
wall outlet->DSl Modem->wireless router.
On the receiving end....wireless card->computer or laptop.
If your desktop does not have a wireless card built-in, then you need the adapter that someone mentioned. It's a minibox with an antenna that plugs into the ethernet port of your desktop.
Hope all this helps. When you add the router you might have to let the provider know its MAC address so that the network can see it.
PSS-Mag's Avatar
Thats just a wireless adapter... You'll still need a wireless router in your home to connect at your home.
Old Sep 5, 2005 | 12:57 AM
ErnScott's Avatar
PSS...the Airport base station IS a wireless router.
Old Sep 5, 2005 | 12:58 AM
I am pretty sure that is the router? On the previous page they were selling adapters, and way less than $200.
http://store.apple.com/1-800-MY-APPL....0.3.1.0.1.1.0
Old Sep 5, 2005 | 01:00 AM
Tical84's Avatar
No, that's a router.
A wirless adapter will be similar to the 2wire adapter you have except for instead of one end plugging into the phone line and one end into your computer, its just one end into the computer and it will pick up the signal from the wireless router, or that airport you mentiond
Old Sep 5, 2005 | 01:02 AM
PSS-Mag's Avatar
Alright lets do this...
You have
  1. Computer number one:
    Desk top with Ethernet adapter
  2. Computer #2
    Desk top with ethernet asapter
  3. Computer #3
    Laptop with wireless adapter
Then follow this diagram.....
http://www.homenethelp.com/web/diagr...ireless-ap.asp
Wall to DSL modem, DSL modem to router, Router to each computer "either via cables or wireless".
Ohhh okay, Bluetooth and all??lol
So if I got the AirPort base Station, and my laptop is already Airport-ready, I will not need an adapter, right?
Old Sep 5, 2005 | 01:03 AM
Tical84's Avatar
right. You will for that second computer thats using the 2wire adapter though
Old Sep 5, 2005 | 01:05 AM
ErnScott's Avatar
Correct-o-mundo
You will not need it for the laptop...you might for the desktop
