Mini putt putt
Old Feb 24, 2004 | 02:08 PM
screwfun's Avatar
Mini putt putt
Putt Putt
Old Feb 24, 2004 | 03:28 PM
Rockpick's Avatar
Moderator &
Great find! This'll be a nice way to spend my lunch each day!
Old Feb 24, 2004 | 04:21 PM
wolf_creek_61's Avatar
best score i could get is a 42 the damn windmill killed me i pulled down a 9 on that one
Old Feb 24, 2004 | 04:32 PM
sirket's Avatar
WOO You found it!
I use to play this game a lot last year and then the site that was hosting it moved.
My best score was a 24 IIRC. I could get a hole in 1 on just about every hole.
-Don
Old Feb 24, 2004 | 04:39 PM
lifeguardjoe's Avatar
Damn, I used to be REAL good at that game. I think I pulled a 21 one time.
I just got a 28
Old Feb 24, 2004 | 04:50 PM
arrbilly's Avatar
42 for a first ever try. I just put that site in my bookmarks!
Old Feb 24, 2004 | 08:50 PM
BlueFlareside's Avatar
Got an 18 but you will have to figure out how I got it. Not really cheating but not really fair.
I don't want to ruin it for everyone.
Old Feb 25, 2004 | 12:14 AM
sirket's Avatar
I just went back through my IRC logs when I was playing the game. I regularly scored a 22-24. Once in a while I could get a 21.
There are a couple of holes where it just isn't possible to hit the ball hard enough to get a hole in one. I am definitely curious how you did this
-Don
Old Feb 25, 2004 | 12:25 AM
PhillipSVT's Avatar
You can get a hole in one on every hole and not have to cheat. Just figure out where to place the putter and the ball and you will sink it everytime!!!
Old Feb 25, 2004 | 01:43 AM
sirket's Avatar
As I said, there are holes where I could not hit the ball hard enough even if I was lined up perfectly.
The 8th hole is one of the holes that I have never been able to hit it hard enough to get a hole in one. It may be possible with higher resolution but on the monitor I play on, I could not make the window large enough to hit the ball hard enough.
-Don
Old Feb 25, 2004 | 01:52 AM
kobiashi's Avatar
Way back when....I got hooked on that game and played it all the time.
The first time I played I scored in the 30's.
Eventually I was able to get a holoe in one on every hole, but there are some holes where that isn't always possible...
(the windmill for instance is a crap shoot)
Best score I got in a single round was 19 and I only did that once. Have scored 21 numerous times....
but then I got bored. It's been a while since I played. Tried it this time and shot 28....got keep playing to stay tuned to it.
Careful though...it's addictive.
Old Feb 25, 2004 | 02:51 AM
sirket's Avatar
Ok so I just scored a 19. I seem to recall having done that several times before so I am looking for the IRC logs. It's been so long since I played that I can't find the logs any more.
-Don
Old Feb 25, 2004 | 02:54 AM
sirket's Avatar
WOOO! Found the logs! Regular scores of 20-21 not 22-24 as I originally thought. Best I ever did was a 19 which happened a few times. Nobody that I knew of was ever able to get a perfect 18.
-Don
Old Feb 25, 2004 | 07:58 AM
Like I said before it is not cheating. I really did get a hole-in-one on every hole. I just have a way to do it without starting the game over at the beginning...hint...hint...
Old Feb 25, 2004 | 02:40 PM
screwyou's Avatar
Yeah, I played that game a while back. I too got an 18. How do you do it, you ask? Well, you can play the same hole over and over until you get a hole-in-one. If you don't hit it in the first time, just right-click on your mouse and select "back," then right-click again and hit "play." Now you can start the hole over again. Do it as many times as needed until you get a hole-in-one.
