F150 Supercrew order info
Hi Setchan,
I just received the DORA for my new F150 and would appreciate it if you could let me know if this is clean. I'm hoping it gets built in Dearborn so very curious to see the factory it gets assigned to (I'm sure that will not be for a little while).
Dealer number: 48G101
Order number: J130
Thank you!
Order number: J130
Thank you!
G48101
J130
Unscheduled- Clean
Drivetrain: 4 Whl L/h Part Time Drive
Series: 150 Series
Engine: 3.5l V6 Gas Dohc Tivct
Transmission: 6 Spd Auto Trans (6r80)
Cab: Double Cab (Crew Cab)
Exterior Color: Sterling Gray Metallic
J130
Unscheduled- Clean
Series: 150 Series
Hi Setchan,
Thanks for the clarification. If you wouldn't mind doing another update I would appreciate it. Looking forward to seeing this get assigned to a plant.
Thanks!
Order number: J130
Thanks!
Order number: J130
Yes, ford knows your name. it will also be on your window sticker
Unscheduled- Clean
Unscheduled- Clean
