F-250 / Super Duty / Diesel
12 on order
Old 09-04-2011, 09:22 PM
klassic's Avatar
12 on order
Just ordered a '12 350 lariat.
Had a 06 250 and a 09 250... hoping the turbo lag has gotten better....??
Old 09-07-2011, 07:59 PM
Powers150's Avatar
Nice i cant wait until a day where i can afford to go to a dealer and pick exactly what truck i want colors,motor,interior etc..
What color ,motor ect did you go with ?
Old 09-07-2011, 08:33 PM
klassic's Avatar
A 350 lariat 4x4 diesel, with FX4 package so I could get the hill decent option.
5th wheel prep.
18's with 3.31's
I was going to get the metallic bronze, but they won't give the wheel lip moldings unless the two tone option selected and I wasn't thrilled with the only option of pale adobe for the two tone.
So I got the pearl blue with sterling grey.
Old 09-07-2011, 08:36 PM
Powers150's Avatar
very nice
Old 09-08-2011, 02:19 AM
Tylus's Avatar
sorry, but 3.31 gears?
and you plan to tow a 5th wheel?
Old 09-08-2011, 08:35 AM
klassic's Avatar
My 06 had 3.73's with "X" amount of HP/torque, my 09 has 3.55's with more hp/torque than the 06....5ver pulls fine. 12500lbs
The 2012 has 3.31's with even more hp/torque than 2009.
I doubted the 2006-2009 transition and it turned out fine. I'm hoping for the same power ratio to work out again.
I drive about 25k miles/year and pull the trailer maybe 4 times... I'm after better daily mpg's vs better towing.
There is a thread here about it http://www.rv.net/forum/index.cfm/fu...d/25370449.cfm
Old 09-08-2011, 10:48 AM
hwm3's Avatar
Clearly you've not driven a truck with the 6.7l and 6-speed. He'll have no trouble towing a 5th wheel with that truck.
Old 09-08-2011, 12:08 PM
Tylus's Avatar
your right I haven't driven one. and I know the 6.7 is a torque monster.
so is my 6.0 with only 570 tq....and yet...it has 3.73 gears and 4.30 were optional.
I've seen manufacturers use high gearsets in the past and the aftermarket is full of companies fixing that mistake with low gearsets. I hope the truck operates just fine with those 3.31 gears. From reading your link, they mostly agreed with me. Other than the fact that the 3.31 gears are so minimal difference from the 3.55 that there is no reason to not get the 3.55's
My major concern is about take-off and low speed tow/haul when the turboo isn't really spooled and you're tugging 10k+ behind you while at low boost.
Old 09-08-2011, 12:48 PM
klassic's Avatar
That was my concern as well when I ordered my 2009 going from 3.73 to 3.55, I even raised a huge stink at the dealership about it, saying I don't get the option to choose 3.73's and they are forcing 3.55's on me... what if I don't like it...I'm stuck with it and nothing I can do about it.
Turns out it is a little on the high side, but easily livable when towing. And to keep that motor from reving above 2k rpms (where it loves to slurp diesel), my 2 hours of daily hwy driving was doing a little better on mpg's. (but the regen would kill it)
Now if this new motor is "better on fuel" and I'm even farther below 2k rpm's, then multiplied by 4 years, I gotta be saving some bucks on fuel.
It hurts forking out 1200-1500/mth CAD on diesel.
Old 09-08-2011, 05:05 PM
hwm3's Avatar
What you're missing is the 6-speed tranny. 1st gear is 3.97:1 vs. 3.11:1 in the old 5-speed. That means even with 4.10 gears the old truck doesn't have as low an overall 1st gear ratio as the new truck with 3.31 gears. Add in the huge increase in power and the truck moves off the line with a load much easier.
Old 09-09-2011, 08:01 AM
adrianspeeder's Avatar
Thats another reason I like a stick...
Turbo lag on your 6.4L? Ever run a 7.3L?
Adrianspeeder
Old 09-29-2011, 09:43 AM
J.Sperry's Avatar
Pics please?!
Quick Reply: 12 on order
