F-250 / Super Duty / Diesel
My superduty is throwin a code
Old May 13, 2010 | 01:54 PM
Pballman19's Avatar
P0506
Idle Air Control System
RPM Low
Now it throwed this code last week, it was runnin all crappy, so i beat my idle air control valve with a ratchet, it drives fine now, but my truck just throwed that code again.
its literally a small chrome cylinder right inside that red circle, kinda a hassle to get to.
any suggestions? ive heard i can take it off and blow it out with canned air, or replace it, or beat it with a ratchet.
seems like itll be a little hard to get at to replace and a new one cast bout a hundred bucks
Old May 13, 2010 | 01:56 PM
MGDfan's Avatar
Originally Posted by Pballman19
P0506
RPM Low
Save the C-note. And just Keep that ratchet handy. Maybe get a bigger one...
Ok - you can always try the zero-dollar approach and clean/lube it (provided you haven't already fatally beaten the crap outta it).
Usually cleaning is a short-tem fix - replacement is indicated.
Old May 13, 2010 | 02:25 PM
Pballman19's Avatar
hey man, i fixed your sig for you
Old May 13, 2010 | 02:26 PM
Pballman19's Avatar
fatally beaten the crap outta it, nah, but i got the hammer standin by for this little pos silver can who thinks he can trip my engine light.
Old May 13, 2010 | 04:55 PM
freekyFX4's Avatar
You could probably clean it out with carburetor cleaner. I think I did that once, when I had one get gummed up on an Explorer.
Old May 13, 2010 | 07:24 PM
Pballman19's Avatar
called a mechanic he said DO NOT use any kinda cleaner, just canned air. i dont feel like tryin to take it off though
Old May 13, 2010 | 07:27 PM
MGDfan's Avatar
Wellsir, if it's all gummed up with crap (as is likely) that is gonna do bupkis
Old May 14, 2010 | 02:41 AM
I've heard WD-40 does a decent job cleaning them. Canned air doesn't do squat.
Old May 20, 2010 | 06:48 PM
SLP 97 CAMARO SS GUY's Avatar
Don't bother cleaning it. Replace it. If it's hard to get to like you say, then I wouldn't want to have to do it twice, if cleaning it doesn't work, see what I mean? Cleaning it may work for a little while, but it is not going to stay fixed lol. Been there, done that.
Old May 20, 2010 | 11:21 PM
f150fella08's Avatar
bud light is nasty
and just replace the thing..
Old May 30, 2010 | 07:14 PM
Pballman19's Avatar
hold your tongue when ur talkin about bud light.
and i cant replace it, i dont have a control valve, its all electronic on my truck. i dont have a throttle cable, its all computer
Old May 31, 2010 | 12:58 AM
If you don't have an IAC, then what WERE you beating the crap out of?
Old Jun 2, 2010 | 02:20 PM
JMC's Avatar
JMC
25 Year Member
Your engine doesn't have an IAC. The little can you have been pounding on is the motor that controls the throttle plate angle. Your P0506 may have been caused by a restriction in the intake tract or a vacuum leak. Is the P0506 the only code?
Old Jun 2, 2010 | 02:34 PM
Pballman19's Avatar
i dunno what i was beatin the crap out of, but i beat it good. yes its the only code, it aint throwin it no more
