engine hours. any way to read ?
Mileage Matters More
Actual mileage matters more. Do you suspect that it was a truck that sat idling??? I know guys that have bought trucks at auctions from highway maint. depts that sat idling more than the miles put that were put on them. (most were gas trucks). They have all had good luck with them because they were well maintained. I idle my diesel for long times in the winter - it uses hardly any fuel and stays warm. Also it does no damage to the body. Not like salt, mud and snow (we had 9 inches last nite) around here. Good luck.:santa:
Thats an 08 and newer option. I don't think the 05-07 trucks could see that or not. I was trying to look at that on my 07 work truck the other day and couldn't bring it up. I know that the 04 and older (old dash cluster) for sure can't see it that way. The only way would be if the PCM logs it.
can anyone verify ???
Yep you're right. I took another look another look on my 07 truck today and it does show the engine hours on the center digital display.
