Truck going in for service
Recently, on my way home from a camping trip, the dreaded check engine light came on. I had been towing my camper for about 2 hrs when we stopped for lunch. After getting back on the hwy, I noticed the engine light. I pulled over at the next stop, ran self diag and did a visual and found nothing. I towed the remaining 3 hrs with a light foot, but noticed that I did lose some power.
Took the truck to Autozone, and they pulled a P0299 (turbo underboost). I'm taking the truck to the dealer today. Anyone else seen this code and / or the fix?
Dropped off the truck yesterday. I'll post results when it's fixed.
Got my truck back from dealer.
From service ticket -- "Pulled code P0299. Caused by 42 ---VGT Turbo Sticking---TSB 8-16-13. Installed VPS and performed VVT Tests per TSB, Turbo failed tests, removed turbo and disassembled for inspection, ring and bearings OK, No coking present, Rust and Scale present on housing, replaced CHRA per TSB, reassembled, retest, sys passed."
Does anyone know what TSB 8-16-13 is?
What would cause rust and scale on housing? Not being driven enough?
TONS of 6.0 info over there.
Please post more info as you get it.
I'm really curious to find out what causes the rust and scale to form. When fuel prices were crazy high, I bought a '93 Nissan pickup to drive to work, and I'm wondering if I should drive the 250 more often to keep moisture out.
