F-250 / Super Duty / Diesel
ERG Removal Tool?
Old Feb 3, 2007 | 02:16 PM
skirk55's Avatar
ERG Removal Tool?
I got a part no. for the tool that removes the ERG Valve in my 2005 F350 Diesel can anyone tell me where to purchase it? The ERG Puller part no. is #303-760
Old Feb 3, 2007 | 04:05 PM
taterthedog's Avatar
I don't know who sells them. I guess you could buy it from a Ford dealer. I only use half of the Ford tool. You could easily make the half I use if you had the measurements. It's only a U shaped piece that hooks onto the ears of the EGR valve. I remove the bolts, twist the EGR valve, put on the tool, and use a big pry bar against the throttle body to pop it out.
Old Feb 3, 2007 | 04:11 PM
skirk55's Avatar
OK I just did not want to brake something pulling it. It sounds like you have it all worked out I will try that. I looked at snap on and mac and came up with nothing!
Old Feb 3, 2007 | 06:49 PM
yeah, I've pulled out hundreds of them like that.
Old Feb 5, 2007 | 09:08 PM
klassic's Avatar
tater.... are you poping it out to clean it occassionally? Is this something that should be done once and a while
Old Feb 5, 2007 | 11:22 PM
We used to replace all of the ones that were giving us trouble. Now Ford wants us to clean them. I clean some and replace some, depending on the voltages it gives me.
