F-250 / Super Duty / Diesel
2007 F-250 XLT, How much $$$?
Old Jan 12, 2007 | 03:07 AM
TwoHulaBears's Avatar
More questions...
Originally Posted by seangranger
It will be hard to find a v-10, so if you can I would get the diesel because with the 2008s coming out you could get a diesel for the same as a v-10 and the diesel gets better mpg and it last longer!
The Ford dealership nearest us has two V10's right now, but I don't like the color of either.
I have been told that if you don't work the Diesel engines alot, they will break down alot. Is this true? For now, I will only be using the truck about once a week to pick up building supplies. Later down the road, I will use it now and then to tow an RV Trailer which at most will weigh 8,500 lbs. Which engine would be the best for me? Also, what is the difference between a 4.10 and a 4.30 rear axle ratio?
Old Jan 12, 2007 | 11:56 PM
crazynip's Avatar
whay makes you think they wont be charging the super premium $$ for the diesel engine like they do now??
Old Jan 13, 2007 | 08:25 AM
BumperB's Avatar
I would recommend the V10 over the diesel for your needs. Yes MPG is better in a diesel but so is the initial costis higher, maintenance is more expensive, and fuel is more in my area. I just see no reason for you to need a diesel. As for gears...have not heard one complaint with anyone that has the 4.30 gears. Hope this helps.
