F-250 / Super Duty / Diesel
Diesel or not to Diesel
Old Apr 20, 2006 | 05:39 AM
Rocweiller's Avatar
Originally Posted by aaronlake
core charge:180 each (wholesale)
What I meant is the amount of diesel sprayed.
Old Apr 21, 2006 | 11:51 PM
KC-10 FE's Avatar
The difference between the duramax and the powerstroke (besides displacement, turbos, blocks, cylinder head construction, engine control) is in the fuel systems pressure. Ford runs a much higher pressure to fully atomize the deisel fuel for a more efficient burn and therefore more power. Better for the engine, the enviroment, but must have clean fuel to work.
Not quite true...
The current Duramax will easily stomp the crap out of the 6.0 PSD. The Duramax makes more power (35 more at a lower RPM), more torque (80 more, & again at a lower RPM), has higher fuel pressure, MUCH, MUCH better trans, more durable/reliable, etc...
http://www.thedieselpage.com/duramax...ewsrelease.htm
I couldn't find a current spec list for the 6.0PSD but here's one for the Duramax. It's clearly a superior engine but it's in an inferior truck. The F250 itself is a far better truck than the Chevy 2500.
I can't afford a $40000 3/4 ton truck, but I sure do want one...
KC-10 FE out...
Old Jan 15, 2007 | 04:38 AM
TwoHulaBears's Avatar
I need to clarify. The injectors are 187 plus a 150 core from Ford. Plus you get 100% of the core back no matter what (that includes engines and turbos, and transmissions too). But it is 1051am and we have sold an additional 7500.
We have sold 8 for 2005
15 for 2004
22 for 2003
Just today.
Are the 2007's having these problems?
