F-250 / Super Duty / Diesel
Rear Axle Question
Old Jan 14, 2000 | 01:36 AM
IKE's Avatar
IKE
Post Rear Axle Question
I have a 2000 F-250 Crew Cab SB with the 5.4, 5 speed, 4.10 L/S, and 4 wheel drive. Is the rearend on this truck a semi-floating or a full-floating design?
Thanks!
<A HREF="http://www.inlink.com/~usguys2/f250.html" TARGET=_blank>IKE
2000 F-250 SD CC 4x4</A>
Old Jan 14, 2000 | 01:44 AM
V10 man's Avatar
Post
IKE
It's a full floater. Take off a rear hub cab and look at the HUGE hub. Aint it purty?
Old Jan 15, 2000 | 01:03 AM
R Bess's Avatar
Post
Ya'll got me curious.. Whats the difference between a 'full floating' design and the semi-floating?
Y2K F250 XLT SC 4x2 5.4L 5sp 4.10LS
Old Jan 15, 2000 | 03:29 PM
Tina's Avatar
Thumbs up
All I know is that it's got to do with how the weight is carried by the axle, I think the full floater the weight is carried by the bearings.
2000 F250 Crew Cab 4x2 6 speed Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, mud flaps
Trailer tow Pkg, Class IV hitch, sliding rear window, running boards
rear privacy glass, 265/75/16 AS OWL tires, am/fm/cassette/cd
Clarion APA 5240 amp
[This message has been edited by Tina (edited 01-15-2000).]
Old Jan 17, 2000 | 09:38 PM
J.C.'s Avatar
Post
On a full floater the weight of the truck is carried on the axle housing, with a semi-floater it's carried on the axles.
If you break an axle on a semi floater make sure you hold on because the axle will come out of the housing and the wheel will go with it. I saw a picture of it once and it looked pretty kewl.
Old Jan 18, 2000 | 01:55 AM
V10 man's Avatar
Post
Full floaters are awesome! The weight is carried by the bearings like J.C. said. There are two, approx 3" diameter bearings on each side of the axle. On a regular axle, there is one bearing on each side. This bearing has to carry the weight and center the axle shaft in the axle tube.
Old Jan 26, 2000 | 05:44 PM
SDF250_mn's Avatar
Cool
go pull the center cap off your wheel...all those bolts around the hub hold the axle in. Pull the bolts and pull the axle and make a trailer out of it ;-)
In terms of breaking a semi-floating axle and it coming out was really only a problem on rearends where the axle was C-clipped in(very common on GM products). The ever so popular Ford 9" uses a bearing retainer on the end of the housing so if you twist an axle at the spline(seems to be most common) the Ford will usually stay in place.
1999.5 F250 SuperDuty, XLT, PSD, SC, shortbox, 4X4offroad, Deep Wedgewood blue, 3.73 LS, 4R100 with PTO, Grey Rhino-liner, Retrax retractible hardtop, camper, tow, Lariat wheels, 295/75/16KO BFG AT,heated tele power TT mirrors, power seat, privacy slider, K&N airfilter, Clarion CD/EQ/DSP, soundstream/PPI amps, JL/Boston speakers, and...
[This message has been edited by SDF250_mn (edited 01-26-2000).]
