V10 Engine Oil
I just picked mine up a month ago. The owner before me used a Volvo Marine 30w synthetic for 51,000 miles.
I changed it to 5w-30 Castrol Syntec.
There are pro's and con's to switching over to synthetic oil late in life.
I believe factory weight oil for the '99 was the same as the '00. 5w-30. If you have been using 10w-30 oil and show no adverse effects(engine noise) with it's use, then continue using it.
Personally I would not switch to synthetic with 50K plus miles. You'll have to listen to other's theory's and thoughts on that decision. Maybe I'll learn something new.
On Edit: I don't think you will notice much change if you decided to switch to synthetic.
What kind of mileage do you get?
Good luck,
Mike
Good luck,
Mike
I have 3.73's in my 99 crew-cab V-10, and I'm running 33x12.50x16.5's. I found my speedo is off .5 mile over 50 miles. I average 10 mpg rural driving, and 7.5 pulling an enclosed 24 foot car-hauler weighing around 8500 pounds.
There seems to be a distinct pattern with the V-10's, some average 12 and others average 10 mpg. My buddy has the identical truck to mine, and he averages 12 for roughly the same type of driving. He also pulls an enclosed trailer and averages 9 mpg. Wish I could figure out what the difference was....
