Aftermarket receiver with Mach system?
http://www.crutchfield.com/S-yFfIA7O...fo&i=120705517
Installed it and it works perfectly. It really brings the OEM little sub to life!
Metra 70-5517 is the number.
I think its only for 99-01 Expy's though. My stock radio had the heat sinks on the radio, so I figure only the sub was ampd. Anyhow, works great!
Originally posted by coolfords
BUZZ
What aftermarket receiver did you get?
BUZZ
I would suggest either a Alpine or Pioneer with time alignment/correction. Really helps with the poor speaker location. Brings the image to the center. I wouldn't buy a cd player without it.
Also, There are only a couple of dash kits that will fit if you have the electronic climate control. And they all have pockets. I uses the 99-5802 Metra. I snapped off the tabs that would normally bolt to the analog a/c controls but wont fit on the electronic climate controls.
I tried 99-5801 with no pocket and it won't fit, at least it didn't fit mine. But I also have wood grain on my center trim.
Originally posted by rainman15
I just called and ordered mine. They said it would work on my 98 too. They said it would be $24.98 with shipping. Does that jive with what you paid? Sounds a little high to me.
Originally posted by Buzzz
Are you getting the oem deck removal tool? Probrably. Its two metal hook looking things that go into the holes on the stock radio. I already had some so I just got the harness which was $14.99 plus 5.99 shipping
I already have them too. I told the guy all I needed was the harness. I already have the mounting kit too because it is the same was the one I took out of my 03 Lightning. The part number on the order confirmation they e-mailed me said it was for a Explorer/Ranger. ???? I called them back and they swear it is the right part for a 98 Expy w/ the mach. I guess I'll find out in a couple days. I don't know if it shows in this pic of my L's interior but that Alpine is the deck I'm going to use.
