Expedition / Navigator
Noise in undercarriage
Old Jan 3, 2003 | 11:24 PM
ncsurveyor's Avatar
Have thumping and knocking noise in area of center/rear of 1999 Expedition 2WD at bumps and slight irregularities in road. Sounds like broken shock or loose tie rod but can't find anything when ti's up on lift. Exhaust is tight as are all cross members and other objects around frame and gas tank. Anyone have any ideas or similar problem?
Old Jan 6, 2003 | 03:26 PM
Johnny A's Avatar
I have a 99 as well and i have the same clunk. I cannot find anything that would cause it other than the exhuast. But my exhuast is tight as well. I have over 100k hard miles on mine now and have no problems. But if you find the noise let me know.
Old Jan 11, 2003 | 04:22 PM
ncsurveyor's Avatar
Johnny A: We have different opinions as to where the "clunk" is, some think it's in the doors, I tend to localize it under the rear seats. Cannot find anything loose up on the lift, but have a hunch it's loose when the truck is settled on the springs and maybe a loose shock is pushed up through the top bolt mount. Would help to get under the thing, eh? Maybe a bushing in either the traction bar or sway bar is gone.
More later.
Old Jan 11, 2003 | 07:17 PM
FamilyRide's Avatar
Most of the time, it's the upper shock bolt, primarily on the drivers side. It's a PITA to get to and tighten properly...
Old Jan 14, 2003 | 09:48 PM
G.Andrews's Avatar
i have the same sounds in my 01.
on a mildy bumpy or rough road, it sounds like there is something seriously loose under the truck.
i think its front suspension related, however it sounds like it is coming from directly under the drivers or just behind the drivers seat.
its most noticeable when slowing down or accelerating on a bad street.
Old Jan 18, 2003 | 09:08 AM
ncsurveyor's Avatar
Well, it isn't the upper shock bolt (a horizontally oriented bolt as opposed to a vertical post and nut) Logical suggestion, but the search is still on.
Old Jan 18, 2003 | 09:12 AM
ncsurveyor's Avatar
G. Andrews: I've sat in the back seats and it sounds to me like it's under them...my grandson thinks it's the back window; wife thinks it's in the doors and the mechanic in our little small town shop can't hear it at all. Guess I should train myself to not hear it as well. When it falls off, we'll know what it was!
Old Jan 18, 2003 | 10:32 AM
Johnny A's Avatar
Its grimlins
Old Jan 19, 2003 | 09:03 PM
karnage's Avatar
Noise
I to have the same noise in my 98 exp.It is making me nuts trying to find it.Checked all the shock mounts, all are tight.
Old Jan 20, 2003 | 10:54 AM
G.Andrews's Avatar
now if there was just a way to string someone up underneath the truck and drive it around while it makes the noise....so they can locate it.
Old Jan 20, 2003 | 10:35 PM
ncsurveyor's Avatar
My mechanic suggested I get on the cart under the truck and he drive around the block...I suggested he do it and he politely declined. What do you pay these guys for anyway?
Old Jan 21, 2003 | 01:58 PM
Johnny A's Avatar
That just might be a fun ride ncsurveyor. You might be able to charge for it.
Old Jan 21, 2003 | 09:49 PM
ncsurveyor's Avatar
Maybe we can make the X-Games with our "Expi Investi-Ride"...***** to the wall noise detection, helmets optional. Good ground clearance preferable. Speed bumps a must.
Old Jan 29, 2003 | 03:30 PM
john928's Avatar
I've had my 99 EB with air suspension for 10 days. The rattle eveyone described is driving me nuts. Hopefully someone will find the cause and post a fix.
Old Jan 30, 2003 | 04:46 PM
FamilyRide's Avatar
Dang y'all for bringing this up.
I'm noticing that when the temps are below say, 40 degrees or so, mine's doing it too. I haven't checked the shock bolt again but that certainly is the same sound I was getting before tightening it, just a lot worse then.
A questions, does everyone that's noticing this have rear LLS? 2 WD? Wondering if it's a chacteristic of the bags when cold.
