GRRRRRR....F@#$ JBA header isn't fitting!!!
I'll try to post the pic. My header is in alignment with the head, however, the bolt passages between the header and the cat pipe collector are off by about 30 degrees. This is just the passenger side. Is this right? I'd think not, but I've never done these before. If they are fubar, I hope I can send them back. Unfortunatley, they've been scratched up trying to fit them in. Kinda like trying to fit a watermelon up a......nevermind. HELP!!!!
https://www.f150online.com/galleries....cfm?gnum=1283
Re: flange
Originally posted by TexfordD
i always thought the flange was free, are you sure it is not just rusted on in that position,soak it with rustbuster or wd and wait a couple of hours and GENTLY tap on either side of the flange
sleep on it
hey,when you start again in the morning ,go back over what you did so that your sure you didnt make a mistake. did you put anti sieze on the egr tube,did you tighten down the bolts in a criss crossing pattern taking three rounds to tighten to specs(very important).are you taking out the inner skirt of the wheel well before you start,it helps alot. good luck and be patient,its worth it
Re: sleep on it
answers
1). 17 to 20 inch pounds.2). be a conturtionist (sic)haha a long extension with a flex at the socket helps and getting in close from above and below helps. p.s. i dont think the anti sieze on the bolts is what you want,lock tight in the medium strength will keep ,em from backing out and leaking plus start up when you,ve got em on but before you put the rest back on and let it warm up then cool, down a couple hours and retorgue (whew its late my spellings way off ) good luck p.s. i also think you may have to undo the motor mount on the drivers side to roll the engine over slightly to get the drivers side in,it,s been five years since i did mine and i try not to voleenter to help on big projects, so my memory may be hazy
LOL....what other side? LOL. Ahhhhh....spent the morning trying to fit the header in. Started trying to undo the forward drive shaft, wouldn't budge. So I ran out to Home Depot and Sears and bought myself a compressor and IR impact gun. I ran the compressor for an hour to break in the motor, then was late for dinner at my friends house. By the time I got back I had to start packing my crap up to go to Michigan in the morning. So.....next weekend...I'll have it done. LOL. Thanks for asking though.
