Exhaust Longevity
Old Mar 5, 2002 | 04:06 PM
Dick 4's Avatar
Exhaust Longevity
Question: Does anyone know what I can use on my Aluminized cat back for extended life.
Such as what primer and paint, any tips would be great.
Up here in NY they like to dump the salt heavy.
Old Mar 5, 2002 | 05:31 PM
WOLVERINE's Avatar
I've done this to my Ranger pickup. Just get some black engine paint and spray it with about 3 or 4 thin coats. Then let it dry about a day. It will smell after you drive it at first. Then the smell goes away.
Old Mar 6, 2002 | 02:43 PM
Dick 4's Avatar
Thanks for the tip
Did you prime it first? What brand did you use?
Old Mar 7, 2002 | 07:50 PM
WOLVERINE's Avatar
I did'nt primer it. That would cause the primer to melt because it can't resist the high temperatures of the exhaust itself. Just get some fine sandpaper, and sand away any rust or dirt that may be on the exhaust. Then, use some high temperature black engine enamel paint(you can get it at any parts store), and spray it down starting with a very light coat. Then spray about two or three more coats on it. Be sure to let it dry betwwen each coat. This will stop the rust from eating through from the outside, but you cannot stop it from eating through from the inside of the pipe. As the condensation builds up on the inside of the pipe, it will eat through from the inside out. I would'nt worry about it. A good aluminized exhaust ought to last you 5 or 6 years. 7 at the most.
Old Mar 8, 2002 | 06:19 PM
Dick 4's Avatar
Ill give it a shot, I haven't put the exhaust on yet but I leave it alone and see how it works.
Old Mar 8, 2002 | 07:39 PM
lrutt's Avatar
Should have just spent the little extra and got SS. Nothing you put on the outside will make it last. Most of the damage is done from the inside where the water condensation collects.
Old Mar 12, 2002 | 04:03 PM
Dick 4's Avatar
Your right
I just sent it back and got a Borla.
Thanks for the tip!
