03 f150 5.4 DOHC swap
Old May 31, 2014 | 10:52 PM
oscar03f-150's Avatar
ok guys i have a 03 f150 which had a 5.4, i bought a lincoln black wood as doner and need as much info as i can get...i bought the adapters and coyote boss intake and need to know what else i need to make this work...if any one has a lead on headers id appreciate it thanks....ill be posting pics as the progress goes
Old Jun 26, 2014 | 12:44 AM
Veteran: Army
like these???
Old Jul 8, 2014 | 05:14 PM
Looks good, what brand are those and what intake are u running on that 5.4 DOHC? Thanks
Old Jul 8, 2014 | 06:25 PM
Do u have any pics of the front view of the engine?
Old Jul 8, 2014 | 07:59 PM
05RedFX4's Avatar
1, you should be able to yank the entire engine/trans combo with computer out of the blackwood and bolt it in to your 150, they are basically the same truck.
2, the coyote boss intake will not fit a 5.4 4v engine, the coyote 4v heads are different than the standard (non vct) 4v heads, and the 5.4 blocks are taller and wider than the 4.6/5.0 blocks so the intake will not fit on the wider valley.
Old Jul 9, 2014 | 12:12 AM
Engine and tranny are in already, i bought the adapter plates to sit the coyote intake, now my problem is to relicate the alternator
Old Jul 19, 2014 | 11:01 PM
Veteran: Army
so much fail with some of that info it's not even funny, plenty of people are using coyote 5.0 intake manifolds on 5.4 based DOHC motors
Old Jul 19, 2014 | 11:06 PM
Veteran: Army
I've got a couple
Old Jul 21, 2014 | 10:13 PM
Hey tarajerame, what intake setup do u plan on using if u dont mind me asking.....im at the point of not knowing what to do since sullivan doesnt have the alternator relocators....i have pics of my build but have no idea how to uplaod em
Old Jul 22, 2014 | 12:21 AM
Veteran: Army
I have three different intake manifold setups, whichever one performs the best will stay, and we'll leave it at that
open an album here or use photobucket to post the pics
Old Jul 22, 2014 | 08:01 AM
Will u be having issues with relocating the alternator?
Old Jul 22, 2014 | 09:09 AM
Veteran: Army
I'm not relocating the alternator, but if I was, I'd have manual steering and install the alternator where the power steering pump was
Old Mar 16, 2018 | 02:02 PM
Ford2002's Avatar
I’m new to the site. Doing a 5.4 dohc swap in my 2002 f150.
I took my brothers heads off his 01 cobra and put them on my truck to make it a 4 valve. I have the mmr spacer kit so I can use the boss or coyote intake. What all would I need in order to make the rest of my swap work. I have the Navi timing cover and wiring harness. If I go with the coyote intake how would I relocate the alternater.
Old Mar 16, 2018 | 02:53 PM
Veteran: Army
throttle body for sure needs to be addressed
Old Mar 16, 2018 | 05:43 PM
Ford2002's Avatar
Mmr makes an adapter for the throttle body as well
