Questions about CAT Delete
Originally Posted by jbrew
Yea, those need to be plugged in, unless they are taken out of the tune completely (deleted) or modified w/foulers or non foulers. Those aren't just checkers as you may think. There's more to those downstreams.
Posted from F150online.com App for Android
Well reading up on this I just found out the info I had before is incorrect and my custom true dual dump under truck rear cat delete might be fairly not bueno. Sounds awesome and feels the absolute same. Guess I'll try the gotts mod and weld in bungs in my new piping I replaced my rears with. otherwise I made sure to keep my stock rear setup somewhat intact so I could weld it back on in case of emergency. Thought that the downstream O2's were simply cat efficiency checkers and the fronts were for A/F ratio checking/correcting. Correct me if I'm wrong, would like to have someone at least answer the O2 sensor question for me if someone could.
Oh and I obviously left the rear O2's unplugged because of my incorrect info that I gathered and the fact that my new piping didn't have a bung in it although it's my plan to weld one in asap anyways. and it is throwing codes, have to check what they are tomorrow.
