custom intake
Old Dec 11, 2012 | 09:18 PM
Kickers5.4's Avatar
custom intake
This may be dumb and ridiculous, but I was bored at work and got to thinking, is it possible to run a PVC pipe from air filter box to intake manifold? Just lookin to get away from the baffles on stock. Wouldn't mind a little extra noise under the hood. Don't wanna spend the big bucks on a manufacturer cai. If its totally ridiculous let me know, thanks
Old Dec 11, 2012 | 09:24 PM
1997 lariat 4.6's Avatar
Hmm the search button must be broke.... PATMAN! Escort this man to the gotts mod for 2004+ trucks... Never mind, I got it! https://www.f150online.com/forums/ch...04-trucks.html
Old Dec 11, 2012 | 09:29 PM
Kickers5.4's Avatar
Gotts mod is done, I have a '10 5.4. I was wondering if outta the box all the way to intake manifold is ok?
Old Dec 11, 2012 | 09:31 PM
not sure about that. haven't messed with anything newer than an 03. I know the gotts mod went through 1997 to now, but the intake tube is something im not sure about.
Old Dec 11, 2012 | 09:41 PM
Kickers5.4's Avatar
Yea I just want a clean straight pipe look. Maybe a little extra noise that sounds good would be a plus.
Old Dec 12, 2012 | 10:24 AM
No, this is going to screw up the MAF metering.
Old Dec 12, 2012 | 12:09 PM
animated_zombie's Avatar
I've done the Gotts mod on my 07 4.2. So I know that it can be done on something newer than an '03! haha... Also I see that you're local. If you choose to go the Gotts mod route and you need help (not that it's really complicated..) feel free to let me know.
Old Dec 16, 2012 | 08:24 PM
06F150STX's Avatar
I think he's talking about from the filter box to the throttle body. Not the fender to the box.
Old Dec 17, 2012 | 01:28 PM
Kickers5.4's Avatar
Exactly. Just want to get rid of those "mufflers" and have a clean look. If maf sensor stays in same spot what would cause it to misread?
Old Dec 17, 2012 | 01:30 PM
diameter, also the way the pipe would flow.
Old Dec 17, 2012 | 08:46 PM
This,
Some things just should not be played with too much. At least with an aftermarket company's kit, if it isn't user error, they will be able to aid help in remedying a problem due to MAF issues.
Old Dec 17, 2012 | 09:18 PM
Veteran: Army
Has any one one of you offering advice bothered to read the "how to's" let alone Jbrew's "thread" with pictures on how possible this mod the OP is wanting to do?
Old Dec 17, 2012 | 09:30 PM
Veteran: Army
Thumbs up
It's about keeping it in the same diameter housing, or else you will need a tune...
As long as you are capable of ensuring all the vacuum lines are hooked back up like stock and the MAF housing stays the same size you'll be fine, just make sure you do a nice write up for others
