How to quiet down intake?
Old Aug 10, 2012 | 11:23 AM
krist003's Avatar
I installed a cold air intake on my 2004 F150 5.4L (AEM Brute Force). It has the polished aluminunm tube and when i really get on the gas it is a noisy bugger. I know it is installed right and doing its job, but was wondering if there are any tricks to quiet it down a bit. When it is under load like towing my trailer or going up a hill with the air on it sounds like the truck is doing mach 10, but obviously not.
I was thinking about wrapping the tube in dynomat or something, but not sure if this will cause any negative impacts. Any suggestions or tricks???
Old Aug 10, 2012 | 03:59 PM
Anotger downfall of an aftermarket open filter intake, noise. Not really much you can do except get custom tuned for it.
Old Aug 10, 2012 | 05:56 PM
BobFinnell's Avatar
Put the stock intake tube back on, install an oem style K&N and do the gotts mod. Then sell your AEM on ebay.
Old Aug 10, 2012 | 09:01 PM
Takeda's Avatar
Put the stock intake back on, including an OEM paper filter. Sell the AEM.
Old Aug 11, 2012 | 07:27 AM
pethel's Avatar
These guys speak the truth! I've been there with a K&N cold air kit. I finally got tired of the noise and reinstalled my oem intake with a drop in K&N filter.
Want to buy a used CAI cheap?
Old Aug 11, 2012 | 08:13 AM
HHT Express's Avatar
More great info here. Glad I found this before forking out $$$$$ for a CAI. I read how to do the Gotts Mod but my question is do you have to do a custom tune after the mod due to increased airflow as I don't have a custom tuner yet? Second question is what does the modd gain you by increasing the air flow?
Old Aug 11, 2012 | 08:58 AM
No custom tune required for the gotts mod....
Old Aug 11, 2012 | 09:30 AM
SSCULLY's Avatar
Originally Posted by krist003
I installed a cold air intake on my 2004 F150 5.4L (AEM Brute Force). It has the polished aluminunm tube and when i really get on the gas it is a noisy bugger. ....<snip>...
Sorry that is the down side of an intake change. Part of the lowered lb/min at the MAS on the factory one, is the design to keep it quiet it down. The part about getting a tune for it, is not going to change the sound. Don't know if the AEM is like the Airaid in not requiring a tune to run it.
Your MY truck ( '03 and older ) does not require a tune for any intake modifications.
Did not do any data logging on your series of 5.4, but the v3 5.4, I only got a 6% increase in lb/min and it was not linear over the range.
The data logging I did on my '01 I went from factory to K&N FPIK to DIY version as the final.
