Looking at Headers
Old Jul 11, 2012 | 09:16 AM
Veteran: Army
It will run like a beast if you get custom tuned. Running no cats hurts if they are just hacked out. However, if you get tuned to run that setup, especially with LTs, it will be angered awesome.
Old Jul 11, 2012 | 09:31 AM
Originally Posted by 1972Formula400
My truck has 94K miles on it...what do you guys recommend soaking the nuts and studs down with. I want to try my best to not break of any studs. Thanks
pb blaster or yield......if your truck is a daily driver start soaking a week ahead of install.....two weeks if the truck sits a lot....
good luck!
Old Jul 11, 2012 | 09:40 AM
1972Formula400's Avatar
Thanks, just trying to get a head start on the soaking. I probably wont get the headers ordered for about another month or so (buying our first house)
Old Jul 11, 2012 | 10:06 AM
yep....keep your resources available when going through a home purchase....good luck on buying the house!!!
Old Jul 14, 2012 | 04:20 AM
MI02SVT's Avatar
i use kroil on rusted bolts and stuff pretty expensive but well worth it and it comes in different forms too like oil or aresol cans
Old Jul 16, 2012 | 08:13 AM
Yeah, we use kroil out here at the plant all the time....pretty good stuff. I am trying that new WD-40 penetrating spray, I'm gonna start soaking them about a month ahead of time.
Old Jul 16, 2012 | 03:21 PM
BobFinnell's Avatar
I will be getting tunes from VMP on a SCT Xcal3 after the headers are on....pretty much whenever the wife lets me after I convince her I need it!
I prefer Don At Lasotaracing.com, His customer service is better and he rote the book on tuning with sct, literally.
I used four cans of VHT but I also did my off-road Y and some other pipe under the truck. 2 light coats 1 heavy all with in an hour like it says on the can.
Old Jul 16, 2012 | 03:39 PM
Ok thanks. I should be able to get by with 2 cans being how I am doing just the headers. Also I will have to shoot don a email and visit with him a bit. Thanks for the help.
Old Jul 16, 2012 | 03:43 PM
BobFinnell's Avatar
Old Jul 17, 2012 | 12:59 PM
What fastners do you guys recommend I use? I am using Fel Pro gaskets btw.
Old Jul 25, 2012 | 02:53 PM
What O2 sensors do I need? Part#? I heard Bosch you could get with the extended harness. Please list the part#, price, and what length the harness I need would be. Just trying to get everything lined up so I can buy everything before I start the job. Thanks again.
Old Jul 26, 2012 | 05:12 PM
Or should I just buy the extender harness from jegs? What length do I need?
Old Jul 31, 2012 | 11:05 PM
BobFinnell's Avatar
I used the bolts that came with the Pace Setters, they have not come loose since I put them on. On the 02's I just extended my truck's wire harness used solder and heat shrink (the truck's harness not the 02's harness).
Old Aug 2, 2012 | 11:17 AM
Veteran: Army
honestly, I'd go with the locking header bolts
you need the extenders for the fronts
Old Aug 6, 2012 | 05:05 PM
I was just curious, with the new headers, how far back do I need to cut the pipe on both sides for the header collector to mate up with the system, I already have the rear 2 cats deleted and the front ones still in place for now until I get my headers for the install. Thanks.
