trying to decide what exhaust?
Old Feb 6, 2012 | 07:13 PM
digbyz's Avatar
I have a 2010 arc reg cab with a roll pan. I currently have si do magnaflow exiting at 90's after both rear tires. I'm doing a flip kit and will most likely need to have it ran differently. I'm thinking I want to do a y pipe after the factory y into to magnapacks, but it looks impossible to do a lightning style exhaust like I want. Id hate to run it out the back and it hit if I bottom out ...... I was also thinking about tucking some shorter dual wall 4" tips back and in line with the roll pan.
What do you guys think ??
Old Feb 6, 2012 | 08:51 PM
You could run 5" - 12" tips over axle, wouldn't drop any more than the shock mounts, and will still get the exhaust tip megaphone effect.
Old Feb 7, 2012 | 01:11 AM
digbyz's Avatar
Your saying dump the exhaust off over the top of rear end?
Old Feb 9, 2012 | 04:56 PM
digbyz's Avatar
Anyone?
Old Feb 9, 2012 | 05:55 PM
Yes.
Old Feb 9, 2012 | 06:53 PM
1fitty_on_24's's Avatar
It would take alot of modification to get your rear bumper 6"s from the ground so you should still have lots of room for your tips out the back IMO
Old Feb 10, 2012 | 01:51 PM
digbyz's Avatar
Ya, you might be right. I would love to get a couple magnapacks on it tho.
Old Feb 10, 2012 | 03:00 PM
I just got my magnapack today and it looks kick *** and on the box it has a % of what the mufflers outperform the oem and my 6" round muffler si/so outperforms a si/do muffler
Old Feb 10, 2012 | 03:02 PM
125% 6" round magnapack
94% si/do magnaflow
They were comparing 2 1/2"
And my magnapack is a 3"
Old Feb 10, 2012 | 05:43 PM
digbyz's Avatar
Hell ya!! I'm going to run 2 with a y pipe I think. So basically an x piped true dual setup. Do they have 3" in and 2.5" out ?
Old Feb 10, 2012 | 09:14 PM
Just get the 3 in 3 out and the muffler shop can make you a piece the goes down to 2.5 cause a 2.5 outlet will
give you a 2.5 core so stick with the 3"
Old Feb 10, 2012 | 10:16 PM
digbyz's Avatar
Sounds good. Should sound awesome. Might recess the tips behind the rollpan. Partially
Old Feb 11, 2012 | 11:42 AM
digbyz's Avatar
Has anyone done a magnapack setup on there 09+
Old Feb 11, 2012 | 02:15 PM
Arklight.
https://www.f150online.com/forums/4730826-post23.html
Setup information on post 1.
Old Feb 11, 2012 | 06:25 PM
digbyz's Avatar
