OBX hi flow kit or Magnaflow cat replacements?
I'm getting sick of my exhaust leak and cat rattles so OBX longtubes are being ordered soon. Should I order the high flow cats they offer or the resonator kit and install Magnaflow cats instead? 2000 5.4 4x4. I take it you'd weld in the Magnaflows, yes? It looks like the same amount of money going either way but wanted to know if the OBX cats suck. Seems a lot of people bought the headers before the catted kit came out so really there was only one way.
Does the Catted System come with Resonators and Cat's? It doesn't seem to say and the pictures for the two systems is the same on the authorized ebay seller I'm looking at. The OBX website doesn't specify either, but i assume it comes with both the resonators and cat's?
Edit: I'm also curious as to whether or not the O2 sensors will need extensions to reach the back of the cat's if you go with magnaflow's that have the bung mounted in the cat itself.
Well in that case I think if i end up getting new headers I'll just get the resonated kit and add in the magnaflow cat's so the sound is mellowed out a little more.
Our winter is surprisingly beautiful so far. Beginning of January and there is no snow on the ground and it's suppose to be in the 50's tomorrow.
I believe most people add catalytic converters to the resonated OBX kits. Weren't you also contemplating getting the resonated kit and maggie cats instead of the kit with cats?
Edit: On second thought, maybe you're right, I'm not sure if there would be room for cat's. I guess maybe the catted system is the way to go and then just drill in bungs after the cats. I wonder if you'd throw a CEL with the catted system without doing the Gott's O2 mod.
on
on
Best bet is to get the kit with the cats and get o2 extensions...
Alright, so if we do this catted kit: OBX Catted Headers
I'm not sure what extensions are best, maybe these: O2 extensions (They're for a mustang, but they should be compatible correct?
These Header Bolts
I'm still unsure what gaskets to get and what O2 sensors to get.
To not throw a CEL, i should just have to drill the bungs after the cats, I shouldn't have to do the full Gotts O2 mod should I?
These Header Bolts
These Header Bolts
These Header Bolts
So Ford O2 Sensors and Gaskets. I was thinking a copper gasket would be better.
Edit: I will go with the Motorcraft O2 sensors, but they don't have Ford gaskets on rockauto.com so I'm still debating what to get for a gasket. Anyone have any good recommendations?
As for where to buy the OBX kit, I prefer to stick with an authorized dealer.
