'01 Supercrew O2 Sensor Debacle
Old Apr 19, 2011 | 08:54 PM
DumpsterDave's Avatar
SES light was on. Ran the code and it said it was the rear two sensors. Got under the truck to change them and found that the rear passenger side sensor wire had been ripped out of the sensor, most likely from bottoming out. The bad news is that the harness/connector was completely ripped out as well so now I just have the four dangling wires. Is there anywhere online that sells replacement harnesses/connectors so that I could splice it in and connect my new 02 sensor.
Thanks,
Dave
Old Apr 20, 2011 | 08:18 AM
You could get extensions and cut the one end off and splice them in....
You'll have to solder the splice connections together....
Old Apr 20, 2011 | 08:02 PM
Thanks 88. Will do. Soldering aint no thang.
Old Apr 21, 2011 | 11:41 AM
avfrog's Avatar
^ There you go.
