Exhaust fluid for new diesels.
Old Mar 23, 2011 | 02:23 PM
x-40oz-x's Avatar
Question Exhaust fluid for new diesels.
I did a search but couldn't find the answers to my questions so basically i was just wondering what is it and how does it work? All i know is it's just a tank you fill up to help with emissions.
Questions:
#1. Is it necessary maintence or not?
#2. Can dealerships fill the tank up?
#3. It is something i could buy in wal-mart and do myself right?
#4. Would the truck run fine without it?
Old Mar 23, 2011 | 02:29 PM
4.6 Punisher's Avatar
I think I know what your talking about, but it's only on certain models. There was one case where a firetruck had that system and it could drive more than 3 miles at a time before shutting down.
Old Mar 23, 2011 | 02:38 PM
stx2006's Avatar
Are you talking about the Denoxtronic based Selective Catalytic Reduction (SCR) solution from Bosch? The little fill port that sits beside the fuel cap on the 6.7L PSD?
Old Mar 23, 2011 | 03:08 PM
x-40oz-x's Avatar
Ya, i think i've heard people refer it to that, but i think the new Cummins and Duramax's have it too.
"Urea-based chemical"
Old Mar 23, 2011 | 03:10 PM
stx2006's Avatar
Yes it's called Urea. I know the Powerstroke an Duramax use it. From what I've read you have to have it in the truck or it wont run right.
On a side note you can pick it up for $13.99 for a 21/2-gallon jug. I think auto zone has it. Never seen it at wal-mart.
Oh and just to poke some fun. The Duramax uses more than the Powerstroke too.
Old Mar 23, 2011 | 03:37 PM
x-40oz-x's Avatar
Ya that was my main question.
From what i've heard dealerships way overcharge for it so we'll probably get some at the shop here if it's necessary for the engine to run right.
Thanks.
Old Mar 23, 2011 | 03:59 PM
stx2006's Avatar
Thanks.
I talked to my dealer about the system on the 6.7L when I had my 6.4L down there getting the oil changed and he said that the truck will start throwing up error messages letting you know it's about to run empty. He couldn't remember how many miles it would go before running out, but from what I've read and heard is that it will run at least 1,000 miles before it runs out. I don't know how much truth is behind that though since I havent jumped on a 6.7L yet.
Old Mar 23, 2011 | 05:06 PM
x-40oz-x's Avatar
1000 miles isn't that far. I was thinking it would have to be refilled around every oil change, be it 3000 to however many miles. It could be more like every 3rd or so fuel fill up.
Old Mar 23, 2011 | 05:46 PM
beechkid's Avatar
25 Year Member
I luv it....ya have ta Pee in yer tank to run "legal" LOL
Old Mar 23, 2011 | 06:17 PM
tim98's Avatar
DEF or Diesel Exhaust Fluid is a Ammonia based fluid (Urea and Water mix) that is injected directly into the exhaust stream after the DPF and Cat. The ammonia in the urea reacts with the NOx emissions to help reduce them among other things. You are going to see this system become really popular because it is extremely effective at reducing emissions in diesel exhaust. If it runs empty, the engine ECU will limit operation by limiting speed, limiting power, or not letting you restart it.
The EPA has mandated that all diesels 3.0L and above to conform to Tier II emissions. Some manufactures are choosing to go with DEF injection and others are using an advanced EGR system.
Old Mar 23, 2011 | 06:26 PM
ALFERALFER's Avatar
I think the tank for the DEF holds around 5 gallons, which should last to till you get the oil changed. A message should pop up on the dash when you are getting low.
Old Mar 23, 2011 | 06:40 PM
x-40oz-x's Avatar
Right on thanks for the responses. We'll definetaly have to look into getting a pump or something here at work to fill up the newer ones then. Especially if it's a must have for the ECU. Thanks again!
Old Mar 23, 2011 | 09:06 PM
avfrog's Avatar
As I stated in the wrong thread...
I am just now hearing of this, and I already don't like it!
DPF delete and a tune!
Old Mar 23, 2011 | 09:07 PM
Smokewagun's Avatar
It will let you know via the message screen well before you will run out.... And it's simple to add. The jugs come with built in nozzles that allow you to dump it in with no mess. When you ignore the low warning and really get low, the truck will go into limp mode and you will be stuck driving under 45 mph.
Old Mar 24, 2011 | 12:04 AM
SupercrewLightn's Avatar
We have a new 2011 ford 6.7 work truck so let me fill you in.. As stated previously, it is a urea chemical injected directly into the exhaust to reduce emissions. We just rolled over 3,000 miles and still running strong- From what the dealer told me it will go between 5000-7000 miles before running out. A warning light comes on and you have to fill it back up. And yes, I love it- here's why- When the truck is running you can stand right next to the exhaust and not hardly smell ANY diesel fumes. That's nice when we start it in our shop and pull it out it doesn't fume us out with the black smoke etc.. I think it's a good thing..
