Going to duals
Old Dec 22, 2010 | 01:22 PM
lakemarykid's Avatar
Going to duals
Well I've had enough of listening to all motor in the white truck. Going to finally do it. I'm at a toss up of deciding between doing 2 1/4" pipe or 2 1/2". 2 1/4" pipe keeping your low end power for towing and 2 1/2" more top end power. Correct? Now, if you are going to run 2 1/4" pipe, when purchasing the mufflers and x pipe do you purchase 2 1/2" so it slides over the pipe?
2 14" Magnapacks-Magnaflow Part# 10415
1 X-Pipe
http://cgi.ebay.com/ebaymotors/ALUMI...Q5fAccessories
2 Magnaflow Part# 35121
Eventually going to run these tips tucked up under the body 45d out the rear. In this fashion
https://www.f150online.com/forums/ex...ipes-pics.html
-Curtis-
Old Dec 22, 2010 | 01:42 PM
migdaddy's Avatar
2.25" for a 2.25" system. they weld together.
Old Dec 22, 2010 | 01:55 PM
rllackey28's Avatar
My opinion is go with 2.5" because the bending will neck it down.
Old Dec 22, 2010 | 03:26 PM
raggidy tom's Avatar
i just did this exact setup yesterday except i used two 14" magnaflow body mufflers not magnapacks. All i can say is it sounds awesome. i went with 2.5" pipe and noticed no loss in low end power.
Old Dec 22, 2010 | 03:45 PM
4.6 Punisher's Avatar
X2
The pipe diameter really gets narrow on the bends.
Old Dec 22, 2010 | 04:14 PM
2.25 if mandrel, 2.5 if smooth bent
Old Dec 22, 2010 | 05:37 PM
avfrog's Avatar
^ indeed.
Old Jan 25, 2011 | 08:46 AM
Well going a different route. I want more of a mild exhaust so I'm just replacing the factory muffler with a 2.5" magnapack and going to run a 4" rolled tip in the factory exit location for a clean classy look. Something that you know is there when stomped but not as noticeable on regular acceleration or cruising. So factory replacement is all. Ordered the magnapack today from PP.
I'm looking for a 4" rolled tip with 2.5" inlet but can't find any in a decent length. Only found a 5" length but looking for more of an 8" length or so. Any suggestions?
-Curtis-
Old Jan 25, 2011 | 01:28 PM
rllackey28's Avatar
My tip is a 4" tip with 2.5" inlet. 18" long. All you need. Got it at Performance Peddler.
Old Jan 25, 2011 | 01:32 PM
rllackey28's Avatar
Just look at these tips, figure out which one you want, and type in the part number at Performance Peddler.
Magnaflow Tips
Old Jan 25, 2011 | 01:33 PM
I don't want one that long though. I think even 12" would look strange. The biggest I've found is 4" Tip 2.5" Inlet 5" Length, which is a tad short i feel. I don't want a whole lot of tip otherwise it will look like it's missing one on the opposite side.
This tip I think would be ideal for a clean classy factory look, but it's only 2.25.
http://www.magnaflow.com/02product/s...e=main&id=9480
-Curtis-
Old Jan 25, 2011 | 06:47 PM
avfrog's Avatar
^ Longer tips sound better.
Old Jan 25, 2011 | 07:12 PM
On the contrary, longer tips look great when angled properly on dual applications. My 4"x18" 45'd
Old Jan 25, 2011 | 07:48 PM
I agree. I am no longer going duals though. Just a factory replacement.
-Curtis-
Old Jan 25, 2011 | 08:14 PM
Probably going to run this tip. Only one I can find in a decent length.
http://www.summitracing.com/parts/SUM-690035/
-Curtis-
