MPG help...new to exhaust
Old Nov 23, 2010 | 12:19 AM
Levi 12ga's Avatar
hey i have a 2003 f150 and would like to get an exhaust set up that will help my mpg go up, i know it probably wont be much but every little bit counts, just put on a lift and would like to try and gain some mpg back. thanks for the help!
Old Nov 23, 2010 | 05:55 PM
skizriz's Avatar
My advice for an exhaust to help with the MPG is to put one on that is as quiet as possible. Leave it bone stock if it's possible.
The main reason being with a nice rumbling exhaust you can't help but put down the windows and roll into the throttle every chance you get. I'd bet my average went down 2 MPG just because of that. You'll never get tired of doing it either.
With a lift and bigger tires, proper gearing would go a long ways in giving you back the lost gas mileage.
Old Nov 23, 2010 | 06:15 PM
Pretend your jewels are strapped to the pedal and do routine and prevenative maintenance.......that will help your mpgs more than anything......you might want to look into regearing or going back to stock tires also....
Old Nov 23, 2010 | 06:47 PM
4.6 Punisher's Avatar
You won't get anything from an exhaust. There's not much you can actually do to improve MPG's in a truck, except maybe a programmer.
Old Nov 23, 2010 | 07:57 PM
regear larger, only thing you can do to gain 'decent' economy back. Lifting it will never help due to wind drag.
Old Nov 24, 2010 | 08:28 PM
avfrog's Avatar
Exhaust will not change your MPG.
Old Nov 24, 2010 | 08:39 PM
It did for mine... but I am good about keeping my foot out of it
Old Nov 28, 2010 | 06:30 PM
Bigwheel's Avatar
I've done it all including new true dual exhaust, CAI and programmer. If you can be disciplined and keep your foot out of the floor you can gain MPG but then again you could probably do that without all the add ons. I had to finally admit that the added expense was for performance and fun, afterall, I drive a 5.4L V8. If you're looking for better MPG get lighter shoes :0).
Old Nov 28, 2010 | 08:08 PM
fine_style150's Avatar
on the contrary it will worsen since you cant tame your foot when your ears want sound....of course you can get away with something by regearing and tunes like these fellas say
