LT Headers into 3" SI/SO?
Old Oct 14, 2010 | 12:57 AM
BlackedOutF150's Avatar
Hey guys,
It's been awhile! Hope all is well with everyone. I recently sprung an exhaust manifold leak on the pass. side. I have been doing some research and it seems LT headers are the way to go. I currently have OEM Y going into 3" pipe and then a 3" bullet si/so. Can i still install LTs? What do I need to make this work? Which LTs are recommended for the best gains/quality? Any assistance is appreciated as always!
Jeremiah
Old Oct 14, 2010 | 01:10 AM
ParnAZ's Avatar
What year truck? What motor?
This is what I just installed on my truck and it wasnt too bad. They were pacesetter #70-2227 for a 97-03 5.4L 4X4.
This is how I ran them together. Personally I think 3" piping is too much on a N/A motor so I ran 2.5". Dont have alot of drive time on the setup so power wise not sure on an increase or decrease but it def. sounds better
Old Oct 14, 2010 | 01:33 AM
2006 F150 FX4 5.4 3v
Old Oct 14, 2010 | 01:41 AM
ParnAZ's Avatar
http://www.sparktecmotorsports.com/h11455s.html
Just do the GOTTS O2 mod on the rear o2's and you'll be set.
Old Oct 14, 2010 | 12:25 PM
IR0NS1N's Avatar
Hell I ran LT with no cats and true duals with an xpipe and two mufflers, then changed it to 1 muffler that was dual in dual out with internal xpipe all 2.5". I now have a Saleen exhaust set up that exits before the rear tires that goes into a aftermarket Y pipe single in and 2.5" dual out and I noticed no difference in power.
My supercharged truck notices no difference with any exhaust set up I've ever had.
Old Oct 14, 2010 | 06:28 PM
I would hope that you had the original X pipe removed.
Old Oct 14, 2010 | 06:46 PM
IR0NS1N's Avatar
Yea
1) Stock exhaust
2) Added supercharger with true dual no mufflers with magnaflow x pipes 2.5"
3) Removed 2 of 4 cats and added dual 14" magnaflow center in center out
4) Added OBX long tube headers (zero cats now) (still had x pipe and 14" maggies)
5) Took out Xpipe and 14" maggies and put single 18" maggie with internal x pipe
6) Put in OBX Y pipe and Saleen Dual side exit exhaust (before rear tires) whole system is 2.5" as is.
As I went true dual same time as Supercharger I cant say an increase from going from single to dual. However going dual to single I honestly feel zero difference between it all.
Old Oct 14, 2010 | 09:47 PM
05crewzer's Avatar
i say if your happy with your 3" single exhaust at the moment then go for it. yes the LT's add more flow and wont be ideal but its a good start.
Old Oct 14, 2010 | 11:13 PM
Will any low end torque be lost? I am happy with my current 3" si/so. I also have some high flow maggies still collecting dust in the attic that i never put in. Should i add these in as well?
Old Oct 14, 2010 | 11:40 PM
05crewzer's Avatar
i would definitely add the maggies to help with the back flow, sound and the chance of being legal.
at normal driving your not going to notice a difference but when you hit it, there will be a loss of torque but wont be horrific. it wont kill your power but 2.5 would be much better in a single n/a.
Old Oct 15, 2010 | 11:22 AM
Thanks for the advice. With the addition of LTs, I definitely want to experience gains rather than a loss obviously. Would changing the OBX Y that comes with the Kit out with a Maggie Y help any? I currently have 3" running from the Y back. Any insight?
Old Oct 16, 2010 | 09:51 AM
Lil help!
Where are all the exhaust gurus?
JK
Old Oct 16, 2010 | 02:20 PM
avfrog's Avatar
^ Changing that Y pipe will do you no good.
Old Oct 16, 2010 | 03:14 PM
BlacknGold's Avatar
Registered User
Im running the dynatech supermax kit with the long tubes and maggie cats and maggie SISO exhaust it it makes a crap ton of low end torque on top of all my other mods. And from everyone I have talked to said its the most quiet vehicle with headers they have driven in. Im sure it helps with that big azz muffler that is one there.
