are straight pipes ok to run on 2010 f150s?
Old Sep 28, 2010 | 11:49 PM
wileybaxter53's Avatar
I just got straight pipes put on my truck (not true duals but split with a y-pipe) and ever since then I can hear a rattle or spark knock in my engine when i accelerate. can straights cause this?
Old Sep 28, 2010 | 11:51 PM
alex7191's Avatar
does it still have the cats?
Old Sep 28, 2010 | 11:53 PM
yes it does. I originally had 2.5 " pipes and thought it was a back pressure issue so i went back and got 2.25" pipes and it still the same. I recently bout a programmer too and when i use it, it just makes the noise get louder so i took the tune off for now
Old Sep 29, 2010 | 11:00 AM
XtremeBawls's Avatar
Old Sep 29, 2010 | 11:15 AM
dsq3973's Avatar
Straight pipes are useless on most vehicles unless it’s a drag car, race car, or forced induction engine (super charged or turbo charged). All a straight pipe does is rob your low end torque and make your truck obnoxiously loud.
Old Sep 29, 2010 | 12:09 PM
TheCrazyredneck's Avatar
the knocking sound happens on all f150s unless you replace the cams and cam limiters and all that stuff
Old Sep 29, 2010 | 12:14 PM
Titan357's Avatar
will it hurt it? IDK
Will it run like ****? yes
Back pressure? myth. you need a properly equalized and flowing exhaust, velocity.
noise? probably just the 5.4L 3v rattle, its a cam phaser thingy.
Old Sep 29, 2010 | 02:03 PM
yeah i have noticed some loss of power in the low range. but why does the noise get louder when i use my programmer? it sounds like somethin is about to rattle out the side of the motor when i run wide open
Old Sep 29, 2010 | 02:22 PM
Ray21's Avatar
Its probably just the ratty sound of running straights.
These newer trucks are LOUD!
Old Sep 29, 2010 | 05:00 PM
If I were you I wouldn't have touched the pipes.
Good lord its a 2010!
Maybe a muffler swap and a tip.
But these trucks sound throaty with stock exhaust.
Straight pipes sound awful.
Old Sep 29, 2010 | 06:58 PM
it sounds good. i had a flowmaster on there but they are just too quiet for me
Old Sep 29, 2010 | 09:08 PM
jakek88's Avatar
i have straight pipes on my 08 f150 5.4L. 2.25" true dual with x-pipe. its not that loud and i didn't lose any power at all. idk how much different the 09+ engines are for sound tho.
Old Sep 29, 2010 | 09:48 PM
avfrog's Avatar
Straight pipes...
Old Sep 30, 2010 | 07:16 PM
f150fella08's Avatar
straight pipes dont hurt anything
Old Sep 30, 2010 | 08:13 PM
I just don't understand why anyone would run straight pipes on something that isn't pumping out a ton of power...if you want loud, what's wrong with going with a straight-through muffler to clean the sound up?
