Will straight pipes with catalytic converters increase horsepower/gas mileage?
Everybody has there own opinion on mpgs, and yes because theres alot of different variables, and the way you drive. But yes cutting off the muffler WILL work. I just cut mine off and welded a pipe in place of it. Sounds damn good if you ask me, helps a liitle on gas, and the best part was it was only about 10-15 bucks worth of piping and i welded it myself. Try beating that price buying a muffler and getting it welded on at a shop. And to answer ur other question, yes a straight pipe WILL work, doesnt need any bends in it. It might move the tailpipe behind the tire back and inch or two, but its not even noticeable. My uncle also cut his off of his and run dual pipes back, also sounds very good as well as mine does too. So either way you go is a good choice. Nomatter what anyone says, allowing the engine to breathe better always helps, and thats what youll get by removing the muffler. Hope this was helpful.
That would definitely be too loud, I was considering it with the four cats because it wouldn't be as loud..but I only know from sound clips on the internet, so maybe it would still be too loud with four.
I'm surprised, I thought if anything I would lose low torque and gain a little up high. I'm guessing a Flowmaster has less back pressure than a factory muffler, someone correct me if I'm wrong..so it should have more benefit when removing a factory muffler. Have you noticed an increase in gas mileage?
Then drop a muffler on there. I have a cherry bomb extreme on my truck. My high flows go on friday. I'll post a vid up Unless you want to stick with the bullet idea
To answer your other question, with the four cats it will not be too loud, if u just dump the exhaust where u cut it off at the muffler itll be loud. But if u do what i did and just weld in the straight pipe, and leave the rest of your stock exhaust piping, itll be loud but not to loud. And despite what others say, its not just noise, it sounds very good with. 4.6s have a good sound to them. Mine sounds great. Thats what u should do in my opinion. Better flowing, better sound, and cheap. Y Not?
