12" Bullet 3" catback
If your truck is 99-03 than run a 3.5". 04-08 run a 4". Good choice on exhaust!
My thread just got jacked
Haha. No worries, glad to hear we're gonna be running the same exhaust. I'm thinking about getting some high flow cats and having the shop fab them in while they're under her as well.
So if I remember right I will have 4 kitty cats under there correct? Two for each side? Should I just remove two of them and put 2 high flows? What would the best set up be?
Welding isn't always necessary. If you ever want to change things up, its much easier. I wish I had bolt in muffler setups so I could run three different sets of mufflers at my leasure.
So will replacing the 4 stock with just 2 high flow throw any codes? Got a little confused by your post
It shouldnt. As long as the o2 sensors are in front of the new high flows it shouldnt be an issue. You might need extensions but thats no big deal. Make sure he plugs the A:F ratio plugs back in that are before the pre cats
