High Flow Cats and Emissions
Old Jun 6, 2010 | 08:47 PM
UNC Lariat's Avatar
I've got a 2007 Lariat 4x4 and I'm about to pull the trigger on a couple Magnaflow 94106s but I've got one last question. I live in NC and certain counties require emission testing. Unfortunately I live in one of those. Will replacing my OEM cats with 2 94106s cause me to fail the emission testing or make it harder to pass?
Thanks in advance guys!
Old Jun 6, 2010 | 08:50 PM
4.6 Punisher's Avatar
As long as the O2's are mounted after the rear cats, then yes, it will pass emissions.
Old Jun 6, 2010 | 09:13 PM
UNC Lariat's Avatar
I figured as long as I wasn't throwing a code I'd be fine on the OBD II part of the testing. The part that concerns me is the "sniffer" they put in the tailpipe.
Edit: I just reread my post and didn't intend to sound crass. With my luck, I'm just paranoid I won't pass emissions and then I'll really be screwed.
Old Jun 6, 2010 | 09:57 PM
It will pass, don't worry.
Old Jun 6, 2010 | 10:37 PM
onelildude's Avatar
Not thread stealing....does hi flows make a difference other than in the tone of the exhaust???
Old Jun 6, 2010 | 10:50 PM
08FX4's Avatar
Not really. I guess if you're OEM cats were plugged they could make a difference in gas mileage but I definitely didn't see a difference. They sure sound good though!
Old Jun 7, 2010 | 12:53 AM
More power due to the less restricted design of the new cats. Not much, but it's an added plus.
Old Jun 7, 2010 | 07:35 AM
batn68's Avatar
I have the maggie high flows in the 3" version and I live in one of these emissions counties. I passed with no problems, no sniffer up the tail...pipe just hooked up to the obd port.
Old Jun 7, 2010 | 07:45 AM
UNC Lariat's Avatar
Thanks for the info batn68. It makes me feel a lot better to know someone in NC passed.
Old Jun 10, 2010 | 03:20 PM
jpf150's Avatar
^me to. I am about to pull the trigger as well. From what I hear, mount the cats as far forward and the o2 sensors right behind the cat and you should be fine.
Old Jun 10, 2010 | 04:28 PM
Only way it could crew you over if if you aren't running the amount of cats they know the vehicle came factory with. Since '97 - early model '05s had 2, and '06+ had 2.
Spot on.
Old Jun 10, 2010 | 04:31 PM
jpf150's Avatar
Darren, Im pretty sure they dont do the visual, just the OBDII. The thing is finding a shop who will touch the cats.
Old Jun 10, 2010 | 04:36 PM
Well in NC, I wouldn't know. Here in PA, the emissions counties do a sniffer, and visual inspection. Just as strict as NY is with it.. Glad I am not in an emissions county.
Old Jun 10, 2010 | 04:38 PM
jpf150's Avatar
Yeah I know, but Ill ask my dad to make sure since he just took my sister's mustang to get inspected yesterday.
Thats some tough emissions. What do you have to do? Just visual?
Old Jun 10, 2010 | 06:39 PM
UNC Lariat's Avatar
Have you found a place yet? I've got a guy in Winston Salem that is doing mine. I know that a 1 and 1/2 hr drive but if you can't find anyone locally... Where in oxford do you live? My wife is from oxford so I'm there every now and then.
