Can i run my exhaust straight from heads?
Old May 24, 2010 | 04:48 PM
fine_style150's Avatar
why do people get the idea that straight pipes are good for the motor? dont they have no backpressure at all therefore interfering with the lifespan of some part in the motor then u gotta rip the block apart and put it backtogether with that new part? i forgot what it was some car nut was tellin me at the autoparts store....didnt know if i shud believe him or not tho...input guys? besides if its junk why would the manufacturer waste money on it? if thats the case id sell truck with just a pipe on it from the headers turned down before the axle and still charge the same
Old May 24, 2010 | 06:03 PM
Scout19d's Avatar
Yeah already set it up to get new headers and pulleys, and also getting the rear diff re-geared. that should do it unitl they make supercharger for my engine.
Old May 24, 2010 | 06:05 PM
Scout19d's Avatar
@finestly, the dealears would do that but LAW sais got to have cats and muffler..... and yes u will lose backpressure not all the time but u can. So just gettin the new heads
Old May 24, 2010 | 07:23 PM
4.6 Punisher's Avatar
Backpressure is a myth cooked up by rednecks that can't grasp the concept of exhaust velocity.
Old May 24, 2010 | 10:16 PM
x2. Velocity, static pressure, scavenging, and temperature is what an exhaust is about. The pipe layout, bends, and sizing, all effect these areas.
Old May 24, 2010 | 10:23 PM
so wut u guys are tellin me is that if an proper exhaust set up is planned out accordingly and for the best of the trucks engine you can do straight pipes? pipe layout size, bends, etc.?
Old May 24, 2010 | 10:28 PM
An exhaust best performs with packed straight through mufflers to retain a good velocity hold for low end energy. Straights are better than any open chamber muffler with baffles though.
Old May 24, 2010 | 10:31 PM
ok, soo.
1. staright thru (magnapack, bullet etc.)
2. straight pipe instead of muffler
3. open chambered
sorri for all this lol i just need to educate myself before i ever give advice to others
Old May 25, 2010 | 09:48 AM
If power is your only concern:
1) Straights
2) Magnaflows/Borlas/Corsas/Bullets
3) Everything else
Old May 25, 2010 | 10:31 AM
JimmysotherFORD's Avatar
what engine do you have?
Old May 25, 2010 | 05:58 PM
1) Straights
3) Everything else
thanks for the info
Old May 25, 2010 | 06:08 PM
ok, soo.
3. open chambered
Yep, and what 4.6 said is pretty much the same. Straights & packed mufflers perform the same under WOT, the velocity hold is better in the packed straight throughs for low end energy is all, which all trucks need to tow and all.
Old May 25, 2010 | 10:26 PM
avfrog's Avatar
Back pressure is real and it is bad for engine performance!
Old May 25, 2010 | 10:47 PM
But sounds wicked awesome when you turn off O/D coasting down a freeway off ramp
Old May 25, 2010 | 10:51 PM
avfrog's Avatar
^ pop pop pop pop pop pop pop BANG!
Ya I'm good...
