Need help with exhaust???????
Old Mar 11, 2010 | 12:12 AM
99F150white's Avatar
hey guys,
my buddy has a 04 f150 5.4L 3valve
I recently just put true dual exhaust on my buddies truck it was 2.25" pipe we cut the y pipe apart and put true dual on and then put a x pipe shortly past where the y pipe use to be. The exhaust was then ran all the way back and exited the truck at 45s with 3.5x18" tips.
I am confused on how quite the truck is, there is no muffler and it is no louder than my old exhaust which the muffler was just cut out.
Did the x pipe really take all the sound away? i was expecting a rap and deep rumble not a truck that had a muffler on it sound..
let me know what you think i should do to make it louder while still keeping perfomance on mind.
thanks
Old Mar 11, 2010 | 08:23 AM
f150fella08's Avatar
that truck has 4 converters...start removing!
EDIT: take out the back ones on each side
Old Mar 11, 2010 | 09:14 AM
MUD DIGGER's Avatar
Bingo to f150fella08, i'm removing my 2 rear cats in the next month or so so mine rumbles a little more with my flomaster... just waiting for a nice day
Old Mar 11, 2010 | 10:28 AM
Thanks for the replys. IF i remove the rear cats will my check engine light come on? or cause me any problems?
Old Mar 11, 2010 | 11:18 AM
MUD DIGGER's Avatar
no because they do not have O2 Snesors so the check engin light should not come on or at least thats what my machanic said
Old Mar 11, 2010 | 11:06 PM
avfrog's Avatar
4 cats are very quiet!
Old Mar 11, 2010 | 11:25 PM
the rear cats arent monitored..just the front ones..you will be fine with running just the front 2 if you decide to remove the rear ones.
if thats not loud enough then replace all 4 with just 2 high flow converters.
Old Mar 12, 2010 | 08:33 PM
Thanks guys.. I removed the 2 rear cats and it sounds awesome..
Old Mar 13, 2010 | 12:33 PM
Good job. Definitely a good DIY exhaust modification for volume.
Old Mar 13, 2010 | 08:25 PM
Daddys55's Avatar
I need help
I have a 2000 ford lightning and need to know what is the best peforming and sounding exhaust
Old Mar 13, 2010 | 08:30 PM
avfrog's Avatar
True dual 2.5" with X pipe and straight threw mufflers like Borla and magnaflow!
Old Mar 13, 2010 | 11:13 PM
Shoreboy21's Avatar
I used to have a 2002 F-150 4.6 with 2.25" running pipe with 3.5" by 18" tips. I had true duals and I'll admit no matter where I went it or what I did was always turning heads and it would set off car alarms on occasion. There again I didn't have an x-pipe.
Old Mar 13, 2010 | 11:17 PM
Shoreboy21's Avatar
Daddys55..I would suggest Flowmaster 10 series..Some places will even tell you that Flowmaster doesnt make them..But they are a one chamber muffler and sound amazing
Old Mar 14, 2010 | 12:32 AM
Yes!
Old Mar 14, 2010 | 12:22 PM
avfrog's Avatar
Flowmaster is out!
He said...
