FLOWMASTER 17403 install question
Old Feb 27, 2010 | 09:12 AM
Gray05STX4X4's Avatar
Question FLOWMASTER 17403 install question
This maybe a stupid question but I am trying to save a trip to the parts store. I have a Flowmaster #17403 kit I am going to install on my 07 SCREW with the 6.5' bed, the directions say to cut 15" off of a pipe (part # 26206) which is about 24" long....measuring from which end is my question? I am assuming that I want to keep the flared end but the instructions don't say.
Thanks in advance for any help!
Old Feb 27, 2010 | 09:22 AM
MGDfan's Avatar
Good morning! Welcome & How are you?
I'll try to help - we'll just let that youngin' Darren, our resident Exhaust Padawan, sleep in a bit
Please review the manual - I'm lookin' at it right now also (linky below)
Trim the REAR of the #26206 pipe - the front part is flared & you want to keep that.
You will be adding this extension between the #26202 inlet pipe, and the muffler inlet - flare will accept the rear of the inlet pipe.
The diagram on page 3 of the instructions are very clear.
http://www.flowmastermufflers.com/kitpdf/17403.pdf
BTW - cutting this pipe will remove the protective layer ( such as it is). You may want to treat it with hi-heat paint (the manual talks about this too).
Good luck - and please accept my heartfelt condolences on choosing a FartMaster kit. Bubba will be real happy, though!
You must have an abundance of low-end torque the rest of us lack that you can so easily give some of it up
Cheers!
MGD v4.1
Old Feb 27, 2010 | 09:30 AM
Thanks for the info!
Old Feb 27, 2010 | 02:35 PM
MGD v4.1
Thanks . I was going to say the muffler inlet/outlets are flared, so that is where the bare pipe goes, flared goes to the inlet pipe, and install as much as possible and double check for length issues.
A bolt on cat-back kit that says you need to cut pipe... FAIL!
Old Feb 27, 2010 | 04:21 PM
rllackey28's Avatar
MBRP was the same way. Their kit fits the different wheel bases and you chop the mid pipe accordingly.
Old Feb 27, 2010 | 07:07 PM
Thanks again!! The only good thing I can say about the kit is its on...and sounds good but it was a pain in the a$$ and the tip doesn't seem to fit right, too loose.
that stupid cut piece damn instruction don't say where it goes..but I figured that out.
My last truck I had installed a Gibson duel swept side and it fit real well, no cutting, just installed and drove off!
I WILL NEVER BUY ANOTHER FLOWMASTER!!! I learned my lesson
Old Feb 27, 2010 | 07:14 PM
MGDfan's Avatar
Tha
Excellent! You sir, are already ahead of the curve!
We can indeed work with that!
Darren is yer Go-To Guy - you can trust him to give you great advice.
Be advised - He does however, come with loyal and very vocal entourage - namely AV & Mr. P.
Me? I know exactly SFA about exhaust, trucks, or just about anything else, so you can safely ignore me....
Cheers bud!
MGD v4.1
Old Feb 27, 2010 | 08:34 PM
Thats odd. They should at least supply the other pipe in the kit, but I guess they do what they gotta do.
They should have at least labeled it with stickers that label where to cut for particular wheelbases.
Old Feb 28, 2010 | 09:42 AM
I'm a little biased when it comes to instructions...I write them for a living. When labeling everything with part numbers for inventory you shoul continue that practice throughout the instruction...assemble part #1234 to #1235...anyway wish I would have asked some questions on here before I purchased...I learned I guess thats the important part! on to the next upgrade...leveling the front end.
