no muffler vs. muffler
Old Feb 23, 2010 | 04:45 PM
tboy12's Avatar
So im kind of in a dilemma here guys so help me out. I lovvveeee the sound of my truck when i had it dumped, no muffler. The problem is that it was dumped so there was very much drone in the cab, especially when i tow (which i do quite a bit). It also just seemed veryyyy sluggish. Like there was night and day difference when i had it run through my muffler. My quiestion is basically why is this so? I love the sound of no muffler, but with all the towing i do its justt a pig! If i took my muffler out and just ran a y pipe would that be any different? i want to keep the "no muffler" sound.
Old Feb 23, 2010 | 04:50 PM
4.6 Punisher's Avatar
The muffler, or lack of muffler didn't hurt you performance, dumping it under the cab did. Run a piece of pipe from the Y-pipe to the OEM exit, or dump it past the axles.
Old Feb 23, 2010 | 05:03 PM
tboy12's Avatar
? well i have a si/do right now exiting like 45 degrees out the back. just relpace the muffler with a y-pipe?
Old Feb 23, 2010 | 05:12 PM
migdaddy's Avatar
no, cut off the muffler and run pipe from that to the rear. Your having one piece of pipe running from the stock Y pipe (which is before the muffler) to the rear of the truck.
Old Feb 23, 2010 | 05:14 PM
RAF150's Avatar
Why does dumping the exhaust under th cab hurt the performance vs. dumping it over the rear axle??
Old Feb 23, 2010 | 05:27 PM
mav015's Avatar
i have no muffler
went to pepboys got a ninety degree piece sounds good looks good
Old Feb 23, 2010 | 06:44 PM
hockeyfanjeff's Avatar
Cut out the stock Y and run a magnaflow 2.5" into 3" Y and run single 3" back to stock exit with a nice tip. Cheap and it'll sound beastly.
Old Feb 23, 2010 | 07:21 PM
tboy12's Avatar
ok that is probably what i will do. but what is wrong with replacing the muffler with a y pipe so i can have my dual exits out the back?
Old Feb 23, 2010 | 07:23 PM
why not cut the stock Y out and put in a magnaflow true-X and run true dual straights if you want duals?
Old Feb 23, 2010 | 07:36 PM
tboy12's Avatar
im broke lol. i just wanna get that sound without doing much
Old Feb 23, 2010 | 08:03 PM
Then you should wait til you have more money. No need to go the cheap route that you will go back and redo later.
Do you have a muffler on your truck right now?
Old Feb 23, 2010 | 08:08 PM
tboy12's Avatar
yes. si/do flowmaster. it is super quiet and i dont know why. i bought it off a guy on here and theres nothing wrong with it but im not real sure which model it is. its just wayyy ttoooo quiet.
Old Feb 23, 2010 | 08:12 PM
Well it's a SIDO and you have stock cats. Just swap the muffler out with a Y-pipe and you can have your straight-pipe sound and still retain your torque.
Old Feb 23, 2010 | 08:19 PM
avfrog's Avatar
^ agreed. I think that is what you are looking for OP.
Old Feb 23, 2010 | 08:21 PM
tboy12's Avatar
thanks guys
