noticeable difference
Old Nov 30, 2009 | 10:37 PM
hondarider180's Avatar
i have a 99 ford expedition with the 4 6 in it i have a k&n cai a poweraid tbs hypertech programmer and a magnaflow si/do exhaust will i notice a difference in power with high flow cats and a less restrictive y-pipe as well and if i add a jet maf sensor will it get rid of my lean code or is there a way to get rid of that with out custom tunes.
i appriciate all the help i can get thank you
Old Nov 30, 2009 | 10:42 PM
Just a minor increase, barely.
Old Nov 30, 2009 | 10:47 PM
YOu are destroying your engine running lean with a tune that can't handle the CAI. Take it off until you can get custom tunes that will mix the proper fuel with the air.
Old Nov 30, 2009 | 11:02 PM
what would happen if i continued to run the lean code would replacing the maf sensor and fuel filter get rid of it or not help at all
Old Nov 30, 2009 | 11:06 PM
You are masking the problem. The computer can't handle the air/fuel mixture. You will burn up the engine, running lean
Old Dec 1, 2009 | 05:12 AM
openclasspro#11's Avatar
you wont gain anything on that engine with a new maf, lose that stinking tb spacer
