Part numbers
Part numbers
about to redo my exhaust, im wanting to do SLP LM2 true duals
for the high flow cats which ones do i need, summit has 2 pages of them
X-pipe- the magnaflow, is it the best one to get, 2.5 or 2.25
the LM2s only come in 2.5, should i reduce down or just run 2.5 all the way out
thanks ken
thanks ken
2.5" will work. some guys run 2.25" but 2.5" will work. Some guys state " it wont give you as much low end torque as 2.25" will"
magnaflow 94106 high flow cats.
X pipe 2.5" (make sure you keep the X pipe as close to where the stock Y pipe would as possible
LM2s 2.5"
and 3.5"-4" tips will look the best. How are you going to exit it?
make sure you dont touch the air:fuel ratior sensor in between the end of the manifolds and cats. also, make sure you plug in each o2 sensor AFTER each cat, that will keep your CEL off.
LM2s 2.5"
http://www.summitracing.com/parts/MPE-10791/
http://www.summitracing.com/parts/MPE-10781/
which X pipe will i need?
correct. you can even crawl under your truck and check it out for yourself.
i believe yall two...i read enough topics in the last 2 weeks on here to tell yall know what yall are talking about
how obnoxious will high flows and slps sound, should i try stock cats first, i want loud but not wake the neighborhood up glasspacky loud
well i got my slp lm2s ordered, and talked to the muffler shop. the guy said 350 for building an x-pipe, running all the pipe installing mufflers and 2-3 1/2in tips
i think i can get him to reuse my tips from the exhaust i have on it already which can save some money
does the price sound decent? this muffler shop is normally kinda priced high but does good work.
