Air Silencer Removed
Old May 3, 2009 | 04:03 PM
DOD 4.6's Avatar
i yanked out the air silencer last night and here's the results:
deeper, meaner exhaust note
a tad more intake noise (and i do mean just a tad)
touchier, snappier throttle response
I think it's a great mod for those who have done the gott's intake mod. and btw, there is no cutting involved - just pull it out with a pair of needle nose
Old May 3, 2009 | 04:05 PM
wfburton159's Avatar
Is this the same as the mufflers on the 5.4 intakes?
Old May 3, 2009 | 04:15 PM
Fordfanatic101's Avatar
can u post pictures
Old May 3, 2009 | 05:14 PM
Where is the silencer? I'm getting my exhaust done Tuesday, the more growl the better
Old May 3, 2009 | 05:18 PM
I just did a search and found some links
http://www.ford-trucks.com/forums/35...-silencer.html
http://www.fordf150.net/howto/airintake.php
I can't tell how complicated it is. The OP will let us know I bet
Old May 4, 2009 | 03:22 AM
DOD 4.6's Avatar
i have no idea about the 5.4
i dont have pics
the silencer is inside the intake elbow. it's like a tube inside a tube. the innner tube is the silencer which is easily pulled out with a pair of needle nose pliers. the only "hard" part is prying apart the rubber grommet thingy (the piece of rubber between the elbow and the air filter box) from the inatke elbow. do this part carefully. don't wanna rip the rubber
Old May 4, 2009 | 03:24 AM
DOD 4.6's Avatar
http://www.fordf150.net/howto/airintake.php <-- these are the directions i used. once you have completed step 8 you will see the silencer. just pull the piece of junk outta there!
Old May 5, 2009 | 01:31 AM
Veteran: Army
the 2 valve 5.4 is exactly the same... the 3 valve is a whole 'nother animal
Old May 5, 2009 | 04:52 AM
#16F150's Avatar
do you think that this can the be done with 09 4.6 3V?
Old May 5, 2009 | 05:03 AM
Veteran: Army
post a picture of the inlet tube...
I'm going to lean on the side of NO since the 3 valves probably use the same parts like the 2 valves did
Old May 5, 2009 | 06:04 AM
#16F150's Avatar
I wish I could post a pic but my truck is being built right now, and I will pick her up in August.
Old May 5, 2009 | 08:34 AM
Thats a hell of a wait, i'd rather have it now and enjoy it in the summer.
Old May 5, 2009 | 08:48 AM
rgecko23's Avatar
I would love to know if someone has taken that huge intake off their 3v 5.4 and opened it up. I just dont get what all the extra plastic is for. Is there a silencer in there? I want to do the PVC mod, but I also want to see if there is any guts that can be removed from the OEM intake.
Old May 5, 2009 | 09:03 AM
You need to read a couple of the threads in the Tech Articles and How To section dealing with the intake mod. Quite a few have cut the silencers off of the 5.4 intake and plugged the holes.
