AEM Bruteforce??
I was REALLY wanting an AEM Brute Force intake, but I waited until I talked to Bill and Corey when I ordered my Gryphon yesterday to get their recommendation. They did not recommend any aftermarket intake, since the Gotts Mod gains the same HP for only a couple of dollars vs. $250-$300 for an aftermarket intake. But still, you gotta love the way that Brute Force looks AND sounds! (I still want one).
P.S. Did I mention I ordered my GRYPHON?
check out this page and click on proof http://bankspower.com/products/show/32/50
Very nice post! Really brought the info to back it up! I think I will stick with my stock intake and maybe try the "GOTTS" mod. Then maybe just replace the filter with an aftermarket drop in. I think the $50 drop in with the $5 GOTTS mod will be much more worth my money....what do you think? Then again the numbers don't lie.....maybe I could spend the extra $ if I knew it was worth it....
If you want the best bang for your buck you could do what I did with my 08 when it was new ,I added Bi-Tron products to all my oils and I use their fuel conditioner all the time. I reached. 23.5 mpg with 800lbs of hardwood flooring onboard. You can check out these products on my web site http://savebucks.bitronglobal.biz
So you think a Dodge CUMMINS is the same as a GASOLINE F150?
He brings up a good point. Numbers directly related to the 3v 5.4 would make the stock comparisons actually mean something
http://www.aempower.com/ViewProduct.aspx?ProductID=1389 (Quote off of their site!)Carbon-Black powdercoated steel heat shield included (when applicable) Inlet constructed lightweight 6063 aluminum and mandrel bent for maximum flow.
Once again metal transfers more heat,therfore losing air density and power gains
you do realize how fast the air is moving through that intke tube dont you. the extra heat is not going to make any difference because the air doesnt sit there long enough. the stock intake flows more than enough air for these trucks, so maybe the banks does flow more air than the rest i dont know but either way it is overkill. talk to any of the tuners and thy will tell that a cai is not needed. if i woud have found this site and learned this stuff i before i bought my cai i would not have bought one.
putting a scoop on a box, then posting the "results" on a website that promotes your product couldn't be considered anything but the absolute truth, right?.....right?
btw, Hoss has it right. The air doesn't dwell in the intake long enough for any meaningful amount of heat transfer to occur. A pot of water doesn't boil instantly on a stove, and a bottle of water doesn't freeze instantly when you put it in the freezer. Same principle.
