Magnaflow 3" SI/SO setup
Old Feb 12, 2009 | 10:25 PM
natron80's Avatar
I'm hoping someone can help me with this. I'm looking to run from the factory 2.5" Y pipe into a 3" magnaflow 3" in 3" out muffler (either the 14" (11219) OR 18" (11249)) then to their stainless tailpipe (15038). The only problem is that I can't seem to find a stainless transition to go from the 2.5" factory exhaust to the 3" on the magnaflow muffler. Any ideas here? Is it something I can buy online or can a local muffler shop take a 2.5" extention pipe and expand it to fit the muffler? Also, is the 2.5" on the truck measured outside or inside diameter? I'd like to just buy the kit, but I can't afford the hefty pricetag (it's a 97 4.6L and I don't want to put a lot of money into it). Magnaflow shows the transition that I need in item 15609 but I can't find it sold anywhere individually. I'd appreciate any help I can get. Thanks!
Old Feb 12, 2009 | 10:35 PM
bigdog87's Avatar
Local shop should be able to fab something up for you.
Old Feb 12, 2009 | 10:53 PM
natron80's Avatar
That's what I was thinking. I'm still not sure what muffler to use. I've checked out a lot of youtube videos. I couldn't find many with the 3" SI/SO setup though. I think the 14" might be too loud. I want a nice low powerful sound when I get on it and when it's idling, but I could do without the loud drone in the cab. I also don't want it to snap too much when I get off the throttle. What do you think?
Old Feb 13, 2009 | 12:17 AM
I would suggest the 14". It will sound great especially on a SI/SO exhaust. Good choice on SI/SO. If I were you what I would do is get a 3" intermediate pipe to make it a true 3" system, best velocity flow with the 3" pipe, and have your OEM Y pipe chopped out and have a Magnaflow 2.5" dual in 3" single out Y pipe connector installed. Much better way to go over having 2.5" expanded to 3", and the OEM Y pipe is very restricted with its 2.5" dual in 2.5" single out.
Old Feb 13, 2009 | 02:50 AM
acruzomatic's Avatar
According to UPS, I should get my 3" si/so 18" Magnaflow muffler tomorrow (Friday) and 3.5" 15 degree rolled tip. I already have a muffler shop lined up and will take it to them as soon as I can to get it all installed. They're going to run 3" piping from the 'Y' back. I'll let you know how they did it and how it turns out.
Good Luck.
Old Feb 13, 2009 | 09:33 AM
natron80's Avatar
Is this the right part number for the Y? 10778. It's not bad at around $25, but how much do you think it would cost to have a shop put it in? That seems it would be a lot of work.
Good Luck.
Are you using the factory Y pipe, or doing what Darren suggested and replacing that too? Any Idea how much it's going to cost you? I'd like to hear some audio when you get it all done.
Old Feb 13, 2009 | 10:33 AM
Yes thats correct. Everything should be around $150 installed.
Old Feb 13, 2009 | 10:42 AM
natron80's Avatar
By everything you mean the entire system? Or just for the Y connector?
Old Feb 13, 2009 | 10:44 AM
bigdog87's Avatar
Everything installed for around 150.
BTW, Magnaflow doesn't really snap, unless you've got other stuff going
Old Feb 13, 2009 | 10:59 AM
kodi's Avatar
Hope you like the 18". I have it on my '09 and it is almost too loud.
Old Feb 13, 2009 | 11:15 AM
natron80's Avatar
So do you think the best thing to do would be to Buy the parts online and just bring them to a local shop and have them put it all in?
Does this seem reasonable? I was looking at allmagnaflow.com and they seem to have pretty good prices. It looks like I can get the Y pipe (10778), Muffler (11219), and the Stainless tailpipe (15038) all for $140.
Old Feb 13, 2009 | 11:24 AM
I called the muffler shop and they told me to bring in the Y but more than likely they won't have to use it. The Y itself on the '07 is at least 3" at some point so I'm only assuming they have an idea up their sleeve.
That price is about right. I wanted to get everything from Summitracing.com, but they didn't have the muffler or tip in stock to I went over to performancepeddler.com and they had everything.
Oh and yes, I'd suggest to buy everything online and take it to a shop. I was quoted a price of 120.00 for the installation/labor and their 3" piping.
natron80's Avatar
What setup do you have? Is it Single or Dual?
Old Feb 13, 2009 | 11:29 AM
Well I have 11" bodies with rear cats removed and they still aren't loud enough
hmm, I don t know. My 2004s Y pipe ducks down to like 2.40" in some spots. Unless you measure yours yourself and verify it then I wouldn't believe it.
Old Feb 13, 2009 | 05:44 PM
phatbak's Avatar
the owner of the shop I went to wouldn't warranty the labor on the parts that I supplied. But if I bought the parts from him, everything would be included in the warranty. It was going to cost about the same whether I supplied the parts, or if I bought them from him, so I saved myself a 1.5 hour round trip to Summit.
moral of the story...make sure EVERYTHING is included in warranty
