long tube on engine
Old Sep 28, 2008 | 06:44 PM
lf22's Avatar
long tube on engine
i was just wondering what the long lube that runs from my air box out to the side of my truck! and i was wondering if i cut it out what would happen
Old Sep 28, 2008 | 07:43 PM
emeguy's Avatar
What? ru seriouse
Old Sep 28, 2008 | 08:32 PM
Umm, well that is sort of your intake, and uhh, if you cut it out, your truck wont get umm, AIR!
Old Sep 28, 2008 | 08:40 PM
lf22's Avatar
is there anyway to cut it so it will get more air i no on a duramax deisel you can cut the air box so that it gets more air
Old Sep 29, 2008 | 01:54 AM
shifty_85's Avatar
errr my buddy cut the top part of the air box off to make kind of a stock CAI on his V-10 exectrition. i donno how he did it thoe.
Old Sep 29, 2008 | 12:42 PM
hurricanesc's Avatar
cutting the intake
What year truck is it.
There are mods for the older body style truck.....2004 and older. You can find those on this forum or on the net.
If it's a 2005 thru 08 then I don't know that I would be cutting the intake. You won't feel any preformance gains and probably won't see a noticeable increase in your gass milage either. It will also weaken the tube and could start moving around the engine compartment....not to mention that it will also start sucking in hot air from the engine as opposed to the cooler outside air that it is pulling now.
Old Sep 30, 2008 | 12:04 AM
Arca_ex's Avatar
I suggest not trying to work on or modify your truck if you can't tell what an intake is...
Old Sep 30, 2008 | 12:22 AM
f150fella08's Avatar
haha couldnt have said it better
Old Sep 30, 2008 | 02:31 AM
shifty_85's Avatar
The gas cap is on the driver side put 87 octane in there do not add oil here. The engine oil is under the hood on the passenger side take the cap off and put oil here do not add gas Good luck buddy
Old Sep 30, 2008 | 02:45 AM
kclark80's Avatar
try one of these. extra 30HP easy
http://www.youtube.com/watch?v=md_Av...eature=related
