Magnaflow install question
Old Aug 5, 2008 | 06:20 PM
Bigmoss's Avatar
I just bought a dual rear exit Magnaflow 16614 exhaust system for my 2008 F150 Lariat.
I was told that unless I was doing the swap on a lift I would never get the OEM system out from under the truck. I was going to back the truck up on 2 of those ramp and get under it from there. Is this true will I have issues removing the OEM setup ? I cannot cut it as it is a lease and I will out it back on when I return the truck.
Old Aug 5, 2008 | 06:44 PM
Wang13256's Avatar
of course installation will be easier on a lift.. but u should be ok if ur up on ramps since ur only ding cat-back, however, im not familiar with the 04 and up F150 exhaust setup.it may be a little aggrivating.. as with most jobs, just be patient...TIM
Old Aug 5, 2008 | 07:17 PM
Irish FX4's Avatar
I did mine in the drivway and i did not even jack it up. Old exhaust came out no problem. Had to do some modifacations to make the new one work. As i have a tow hitch. No big deal.
Old Aug 5, 2008 | 07:31 PM
ftl40's Avatar
i also did my system in my driveway without jacking it up. the stock exhaust will come out just have to twist and turn it a lil. took me an hr start to finish to do mine
Old Aug 5, 2008 | 08:03 PM
Bigmoss's Avatar
Thanks guys thats what I ws hoping to hear, mine should be here end of the week
Old Aug 5, 2008 | 08:56 PM
Wang13256's Avatar
good luck and let us kno how everything turns out
Old Aug 5, 2008 | 09:02 PM
Wang13256's Avatar
the only thing i would change on those systems is the muffler size.. i would rather have a 14'' instead of 18''.. but itll be good
Old Aug 5, 2008 | 11:14 PM
BigBlue5.4's Avatar
Cut your tailpipe behind your muffler.
Old Aug 6, 2008 | 08:59 AM
Bigmoss's Avatar
Did you read my original post at all ?
Old Aug 6, 2008 | 10:05 AM
Irish FX4's Avatar
Doh!!!
Old Aug 6, 2008 | 11:14 AM
BigBlue5.4's Avatar
Actually I read it down to that last sentence. My bad.
Old Aug 6, 2008 | 11:30 AM
TRUEBLUE2004's Avatar
you can still cut it as long as you cut it in a straight area of the pipe. Then you could put it back together pretty easly. The only reason I'm saying this is mine wouldn't come out, but mine is an 04 which i believe my muffler is larger than yours and may have been my problem. Any way good luck w/ it.
Old Aug 6, 2008 | 02:02 PM
MagnaFlow_Rep's Avatar
Former Sponsor
Thank You we appreciate your business. Just make sure that your cab & bed configuration is a EC-6.5' Bed or a CC-5.5' Bed
Old Aug 6, 2008 | 03:01 PM
Drop the muffler from the front and pull the tailpipe along with, twist & turn as needed, you'll be alright. Thats how the shop took mine out, too 1 minute.
Old Aug 6, 2008 | 08:34 PM
ftl40's Avatar
i just used a bfh to get the pipes apart
