Exhuast Question
Exhuast Question
ok, i have a the magnflow si/do dual rear exhaust
i want to change it up, and make it the Dual side exit Split rear , the one where theres one tip on each side of the truck.
question is can an exhaust shop just bend current one i have, or can they make me one and if so, about how much am i lookin??
thanks fellas
thanks fellas
Yep, they should be able to use most of the pipe on your current set-up. Just bend some pipes so they'll exit behind the tires.
A complete dual exhaust will run where from $200-400. Just having those pipes bent and welded to the exhaust you already have should be a lot cheaper.
the setup in your videos under ur sig?
i want ur setup Darren , but the 45ed slash tips
wat do u think??
I had some pics in my gallery of what you want.
If the pics are still there.
ETA: I don't think they're their anymore. I'll have to see if I can find some. You can do a search for exhaust pics or exhaust setups and they'll probably be there.
yeah i ve searched , but ur gallery/ pics arent there anymore
