Cat Questions
Old Jul 12, 2008 | 01:57 PM
RLTW's Avatar
Cat Questions
I live in Georgia where there are no emission laws. I drive a 07 FX4. Being that I want to remove my cats all together. I want to know if I do if it will throw off my computer system and if i need to replace them with X pipes or what I need to do.
Old Jul 12, 2008 | 02:01 PM
joshcheste1's Avatar
If you remove them completely you should throw a CEL. That will drive you crazy on a new truck. Just throw on some hiflows, they will keep the CEL off. If they did remove them they would probaly just weld pipe where they use to be.
Old Jul 12, 2008 | 02:28 PM
RLTW's Avatar
I have duel Flow masters on it now i just want somthing deeper and more angry
Old Jul 12, 2008 | 02:40 PM
Hi-Flow cats will do that. Part # 94306 will work proper for your cat replacement.
Old Jul 12, 2008 | 03:43 PM
check my vid out i have a si/do with hiflow cats. That will give you an idea.
Old Jul 12, 2008 | 05:33 PM
RLTW's Avatar
Sounds good thanks for the help
Old Jul 12, 2008 | 07:32 PM
Thanks man, the hiflows will give you what you are looking for.
Old Jul 14, 2008 | 09:26 AM
carlschmarl2's Avatar
I have an 04 and I was wondering if that's the same part number that I would need for my cats? How would I go about doing it? I am pretty sure since my truck is an 04 that I have 4 cats versus the newer trucks with only 2...Do I order 4 high flows or do I just stay with two? Which stock ones do I replace with the high flows? Thanks.
Carl
edit: I see now that the cat you listed is a magnaflow. Will that cat work with a Roush Off-Road system or do I have go with the Magnaflow system?
Old Jul 14, 2008 | 09:56 AM
Carl
Just order two. I'm going to order those sometime soon. They will go a little bit after the downpipe bends down and straightens out ( after pre-cat ). The O2 sensors need to remain in the same locations, the hi-flow cats will just sit in between where the old rear & front cats sat. Not supposed to set of a CEL, thats my only concern. Troyer Performance says they will work correctly on any 1997+.
Old Jul 14, 2008 | 11:55 AM
So I am removing all four cats only replacing two with the high flows?
And how will the Magnaflow cats work with a Roush system? Or do I need to do an all Magnaflow system?
Old Jul 14, 2008 | 12:16 PM
phil6608's Avatar
It will be fine. You don't have to have an exhaust system all made by the same company. lol
I have Kooks headers,,Bassani high flow cats,,Magnaflow X pipe and Flowmaster mufflers.
Phil
Old Jul 14, 2008 | 12:19 PM
mhockey9090's Avatar
sounds good i did the same thing but removed all cats and its loud as hell you can hear me from like a 1 mile away its badass
Old Jul 15, 2008 | 12:49 AM
97XL's Avatar
When you get them done make sure you ask for the old cats back. You may be able to get some $$$ for them from a scrap metal dealer. On the older cars/trucks you can get some good $$$ on the newer ones prolly not as much since they use different materials now to do the same job. I got $200 for my 11yr old cats.
Old Jul 15, 2008 | 10:11 AM
So am I cutting ALL FOUR off and only replacing with TWO high flows?
Old Jul 15, 2008 | 10:22 AM
Correct.
The two hi-flows will fit in between there the original two cats were.
