Duals or Dump Opinion
Old Mar 28, 2008 | 11:18 AM
DBell's Avatar
Guys, I have '07 F150 Supercrew 4x4 and want to upgrade the sound of my exhaust. Should I run duals straight out the back with stainless tips or should I dump so you can't see the pipes? Since I have a 4x4, what would look better? Any opinions?
Old Mar 28, 2008 | 11:21 AM
joshmac4.6's Avatar
I wouldn't run straights out the back, it sounds like trash IMO. If you are on a budget and these are the only two options, dump it, if you can afford a good setup, go true duals, with an x-pipe and magnaflows or borlas, something nice.
Old Mar 28, 2008 | 11:33 AM
DBell's Avatar
I no pretty much nothing about exhaust other than I like the sound of it... if i run true duals with an x pipe, i guess i would have 2 pipes coming out the back? maybe with 3 1/2" tips?
Old Mar 28, 2008 | 11:36 AM
joshmac4.6's Avatar
Yea, I would advise putting mufflers on it if you run it out the back. My vids are below of my setup, but out the back changes the sound comp. I had 3.5" tips with my flowbastards and changed them to 4", they sounded alot better than the 3.5".
Old Mar 28, 2008 | 11:40 AM
DBell's Avatar
10/4... i appreciate the help.... i'll take a look at the 4" tips...
Old Mar 28, 2008 | 12:20 PM
grizzstang's Avatar
This is the set up I have but with 3" tips. If you like it loud skip the mufflers and the X pipe. I just added and X pipe and it cut the sound by half. I like the way it sounds with and without the X pipe I just did not like the popping you would get with out the X.
Old Mar 28, 2008 | 12:24 PM
joshmac4.6's Avatar
X doesnt reduce loudness at all, I had with and without and the sound is no different. It changes the tone and increases the scavenging, and always no matter what improves performance. If your x changed the sound, then it is junk.
Old Mar 28, 2008 | 12:52 PM
DBell's Avatar
Okay I have to ask, what exactly is an X pipe? I wander if this comes standard with duals or should I request it?
Old Mar 28, 2008 | 12:53 PM
grizzstang's Avatar
The consensus from what I have seen on this forum is that it does indeed reduce loudness. I can tell you for a fact it did on my set up. As for my x pipe being junk, it looks good to me. It is a custom made one as I added it after the rest of my exhaust was already done. The guy said he built it after the Magnaflow x pipe and it does look very close, it is just not stainless steal.
An X pipe looks just like an X. Both sides of your exhaust meet in the middle. You would have to request it.
Old Mar 28, 2008 | 01:04 PM
DBell's Avatar
10/4, thanks!!! and what exactly is the purpose of the X pipe?
Old Mar 28, 2008 | 01:12 PM
grizzstang's Avatar
It balances both sides of your exhaust by mixing them together and creates some back pressure which in turn improves torque.
Old Mar 28, 2008 | 01:18 PM
joshmac4.6's Avatar
Here's mine, there is no standard true dual system it wo't be standard, my setup ran me $160, and it sounds better IMO than any catback.
Old Mar 28, 2008 | 01:28 PM
DBell's Avatar
got it, thanks for the info!
