Optons for side-exit exausts?
Old Nov 20, 2007 | 11:05 PM
The Weez's Avatar
Question Optons for side-exit exausts?
I'm noticing that many of the performance exhausts have dual rear exits. I don't really like that look. What are the options out there for side exits (behind the rear tires)?
Also, what's really the performance benefit of a cat-back on a late-model 5.4L? Will it actually get me another mpg? Or is it pretty much just show and sound on a stock-motored truck?
Old Nov 21, 2007 | 12:03 PM
MagnaFlow_Rep's Avatar
Former Sponsor
You could have a shop install one of our mufflers (Single In/Dual Out) and have that installed behind the tire.
Old Nov 21, 2007 | 12:11 PM
hivoltagefx4's Avatar
Well, the combination of a CAI and a good exhaust system will help your truck breathe better. With that, you "may" increase gas mileage a little. The big thing you will notice though is an increase in performance. You'll be surprised how restricted our trucks are!
Old Nov 21, 2007 | 01:20 PM
ParkM's Avatar
Do what I'm in the process of doing, replace the factory Y with a Magnaflow X pipe followed by 2 Magnaflow SI/SO mufflers running the tips wherever you want. Depending where you are located, you can also do long tube headers and replace the factory cats with high flows. You should see about 30 rwhp if you do all that.
Old Nov 21, 2007 | 03:04 PM
clsouthpaw03's Avatar
I didnt want the rear exit duals either. I got Corsa si/do behind the rear wheel. Check their website. www.corsaperf.com They have some sound clips too.
Old Nov 21, 2007 | 06:06 PM
The Weez's Avatar
Well I don't see my truck listed. 2006 F150 supercab 6.5' bed. Unless I'm reading this wrong.
http://www.corsaperf.com/ford.htm
Old Nov 21, 2007 | 06:08 PM
The Weez's Avatar
Recommend a particular muffler(s)?
Also, if I have a shop do the install, what size of pipes do I need downstream of the muffler?
What size is it upstream of the cat-back?
Old Nov 21, 2007 | 06:16 PM
riceh8r's Avatar
magnaflowrep...wouldn't the 16612 kit work for the 6.5 bed?
Old Nov 24, 2007 | 02:29 PM
ws6_guyscrew's Avatar
an exhaust shop will do the tips however you want, infront of tire, behind, angled... an so on
Old Nov 24, 2007 | 02:38 PM
shifty_85's Avatar
wish the gas tank was somewere else so you could have true duels coming out before the rear tires
Old Nov 24, 2007 | 02:51 PM
Jughed's Avatar
Just drill through the tank Shifty, It will give you more clearance too. Just make sure you weld it up real good on the ends! Added bonus:it will take less money to fill up!
Old Nov 24, 2007 | 03:27 PM
shifty_85's Avatar
haha hot gas is always good for your truck to! i tryed to see if i could snake a pipe by put itd be rested on the tank and im like....no if it was back about another 5 inchs i could get it threw safely lol. or if it was a bronco type tank just jump the axle without having the true duels fallowing each other to the rear axle.
Old Nov 24, 2007 | 10:48 PM
Jughed's Avatar
I wanted to do the same thing, bout impossible without putting a fuel cell in the bed and droping the tank.
Old Nov 25, 2007 | 12:36 PM
shifty_85's Avatar
why couldnt i just put my spare in the bed and put a bronco tank there? extend the fuel lines and move the filler. itd take a weekend of work and id deff mount it and find out if the lines and filler would work. i dont see why it wouldnt...oh the fuel pump i forgot thats in the tank...hummm
Old Nov 25, 2007 | 12:49 PM
Jughed's Avatar
Could you section the top of your existing tank onto the Bronco Tank? Moving that much weight a couple feet back would help get some wicked launches. It would be a lot of work but with a Plasma cutter and a welder anything is possible.
