Check Engine Light
Old Nov 14, 2007 | 09:46 AM
squirtbottle09's Avatar
Check Engine Light
I recently purchassed and installed AEM brute force CAI. Everything went great until I got in and went to town and my CEL came on. I came home and checked everything, then reset my battery. The engine light stayed off all the next day, but this morning on my way to school it came back on. I have read that if the engine is running lean it could trip the CEL. Why does the light only come one sometimes if this is the case? I have not been able to make a trip to autozone yet to get it checked. The truck still runs fine and everything, no problems at idle. What could be the problem?
Old Nov 14, 2007 | 09:58 AM
05supercrew's Avatar
Its probably running lean. Definitly get it checked out. You dont want to run lean to long. If its lean put back your stock system and get a custom tune.
Old Nov 14, 2007 | 10:15 AM
jbrew's Avatar
Did you clean the MAF well before installing the new intake? You have more air flying by that sensor now. The PCM will not be able to adjust mixtures properly if the air coming in isn't getting metered correctly..
Old Nov 14, 2007 | 12:45 PM
I will clean the MAF sensor when I get home. Is there a special way that I need to clean it?
Old Nov 14, 2007 | 01:05 PM
MmmBuckles's Avatar
you can get MAF cleaner at autozone. or an electrical contact cleaner would work too.
Old Nov 14, 2007 | 01:42 PM
projectSHO89's Avatar
Guessing at the cause of the CEL is no substitute for having the fault code(s) at hand.
Get the code(s) pulled.
Steve
Old Nov 14, 2007 | 05:08 PM
I will try to get it read as soon as possible. But the nearest autozone is 30 miles away, and at 10mpg at 2.95a gallon I try to limit my trips up there. I have some electrical contact cleaner at my house though. After removing it do you spray all of it, just the part that hangs in the tube, or what?
Old Nov 14, 2007 | 09:27 PM
Cleaned the MAF and noticed a diffence. The CEL is gone for now, lets see what happens in the future.
