The Gotts Intake with pics
Old Jan 6, 2011 | 02:21 AM
  #361
Veteran: Army
there's actually two lists, I'm going to combine 'em eventually
Old Jan 6, 2011 | 09:05 PM
  #362
Silver T's Avatar
On this mod how did you guys stop the PVC pipe from shifting when getting on the gas? It doesn't shift much, but enough you can hear it creak on the medal of the fender wall it's fed through. Did you just stuff the PVC into the fender so tight it doesn't move all when the intake flexes or did you leave the hose clamp slightly loose so that remainder of the stock intake can slide up and down the PVC as needed? Please let me know if I'm not making any sense.
Old Jan 6, 2011 | 10:31 PM
  #363
eghead's Avatar
I just tightened the hose clamp all the way. The original snorkel piece wasn't flexible, so I wouldn't suspect there is a need to allow it to slide on the PVC.
Old Jan 6, 2011 | 10:55 PM
  #364
Silver T's Avatar
eghead,
Is your PVC pretty snug in the fender? I can still pull mine out using my hands and I've tried to force it in tighter, maybe I just need to take it apart and lightly tap with a rubber mallet to really get it snug.
Old Jan 6, 2011 | 11:21 PM
  #365
eghead's Avatar
eghead,
Yep, it fits perfectly snug all the way to the lip of the inside of the fender wall hole. I used sewer pipe so I didn't have to sand or file the PVC walls down, and it fit perfect. It's tight enough that I have to rotate it a bit to get it out.
I think another reason it doesn't go anywhere is because of how long I cut the pipe. I really had to wedge the pipe into the intake pipe to make sure it stayed in there. I cut it just long enough to leave the 3 small holes in the bottom of the tube opened.
Sorry to ask a dumb question, but you did replace the bolt that holds the intake down, correct? I know there is flexing even with it bolted down, but it's not enough on mine to make the pipe budge.
Notice in this pic how long I left the pipe
Old Jan 7, 2011 | 12:52 AM
  #366
Barrett's Avatar
Never knew there was a list... unless I signed the other one when I did it.
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
104. Moosenuckle
105. Barrett
Old Jan 7, 2011 | 06:39 AM
  #367
expy03's Avatar
Your never going to get the list complete. There was a whole bunch of us that did this mod back in 04-05. About a hundred of us got the original EDGE tuner, and most removed the snorkel at that time at the recommendation of Bill. Some put the PVC pipe in, some didn't. Really didn't make much difference. I still have the pipe I used on mine, setting on a shelf in the store room. I eventually went with the airaid jr setup which is a very clean, functional setup. Gets air from right behind the headlight, much like the 5.4 superduties.
Old Jan 7, 2011 | 08:41 AM
  #368
Silver T's Avatar
I have it tightened down, but the bellows flex slightly. I'm not talking much, maybe a few millimeters at best, but it's enough I can hear it against the fenders metal. After rereading some of the threads I went back and compressed the bellow all the way so we'll see if that stops any of the flexing. Thanks guys.
Old Jan 8, 2011 | 08:21 PM
  #369
Jus Cruisin's Avatar
I haven't done this mod and I am not even sure it applies to a 2010 5.4l but how about this idea. Take a small vacuum hose, split it length-wise and then use it to form a "gasket" around the opening to keep the pvc pipe away from the metal. Yes/no?
Old Jan 9, 2011 | 08:48 PM
  #370
Silver T's Avatar
I think the compressing of the bellows actually took care of it, at least for now. If that doesn't work I may try the hose idea as a gasket of types or even just a thin layer of electrical tape pending on what I can squeeze. Thanks again guys.
Old Jan 11, 2011 | 10:27 AM
  #371
iHellFire's Avatar
yea now i had the same problem with the creaking...what i did is went and bought the double sided tape, kind of like the weather stripping, and did one strip around the PVC and then shoved the PVC back into the fender well and haven't heard it since!
Old Jan 12, 2011 | 09:16 AM
  #372
lenore's Avatar
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
104. Moosenuckle
105. Barrett
106. lenore add me to list.
Old Feb 13, 2011 | 03:05 PM
  #373
MUDDUCK7's Avatar
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
104. Moosenuckle
105. Barrett
106. lenmore
107. MUDDUCK7
Old Feb 13, 2011 | 03:12 PM
  #374
DarkShadowSTX's Avatar
108. DarkShadowSTX
Old Feb 13, 2011 | 03:28 PM
  #375
06F150STX's Avatar
109. 06f150stx
