The Gotts Intake with pics
Finally completed Gotts mod today on my '07 3V 5.4L. It was really cheap, easy, and there seems to be a nice improvement in throttle response. Thanks guys!
I used 3" sewer line instead of PVC, because the pipe wall is thinner. I didn't have to do any sanding or filing, and the pipe fits perfectly snug in fender hole.
Before (stock)
Remove stock snorkel (I just pried it off with a flat head screwdriver)
Use 4" to 3" connector for coupling of the existing intake housing and the new Gotts intake pipe
Cut about 16 inch length of 3" Sewer line to replace stock snorkel. I cut it long enough to fit far enough in to be firm, but short enough as to not cover the small holes in the bottom of the intake housing. You can see that the pipe wall is a lot thinner than standard PVC.
Painted sewer line and inserted into fender well. Little effort to slide in,yet snug enough to stay with no sanding or filing
Reconnect assembly to new intake pipe at the coupler and done. Completed Gotts Intake mod. (Don't forget to disconnect the negative battery cable for at least 10 minutes to reset ECM)
And for a special bonus, I replaced my air filter with a new Amsoil to maximize performance increase from my new mod.
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
Before (stock)
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
I did mine a month or so ago with the DVM pipe and downspout coupler method. I didn't like the way the rubber coupler only went an inch our so into the fenderwall. I replaced it yesterday with just the 3" DVM pipe that I had left over. Had to spend about 45 minutes grinding and sanding to get the pipe to fit, but now it goes a good 2-1/2" into the fenderwall. Seems to have a slightly better throttle response, but I also cleaned out my throttle body at the same time, so that could have also helped.
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97.ScrewedUPF150
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97.ScrewedUPF150
just updating the list... I did it yesterday also I clean the MAF sensor.
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
Forgot to add myself to the list. Who's going to be magic #100???
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
Alright so basically I followed eghead's instructions and pictures, just got done doing mine, spent $15 for everything...took about an hour. I am about to go to my hunting camp tomorrow so we will see how my MPG goes....just to make sure I disconnected the negative side of the battery for about 20 min.....was that enough amount of time to reset the ECU?
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
#103
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
i need a check list before i go to lowes! anybody help me out? lol i wanna get all the parts the first time because its about a 20 minute drive one way so i want to get it all the first time. its a 2004 4.6L. it has the cone style air cleaner if that helps. so its not the straight tube looking one, it has the big area for the air cleaner
#103
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
104. Moosenuckle
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. RChittenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Biggoldie
65. samirar
66. FlashmasterK
67. Rojo024
68. MikeChris2
69. sean46
70. CGpinoy
71. Tommer
72. rdicarlo
73.Wolff-SATX
74. Trucky911
75. jdub96
76. Blue02FX4
77. islandfordguy
78. TJA349
79. Spyawn
80. BLUE20004X4
81. OVER_KILL
82. PapaBare
83. SFCFX4
84. bogeyrider63
85. dumontdude10
86. LonestarROB
87. low bass
88. Jared Lutes
89. Pockets
90. recountry2
91. Hiwire
92. BLFX4K
93. vaipunk
94. Jaxson
95. Motox852
96. eghead
97. ScrewedUPF150
98. Borrego97
99. BigTerp
100. RobPad
101. ParnAZ
102. iHellFire
103. sam1947
104. Moosenuckle
